hotoval1 0 Posted October 31, 2005 The oil pressure light and warning bleeper are beginning to upset me. The sensor goes off when the oil is hot and the engine reving between 2K and 2.5K RPM. It does not go off above or below those figures and is fine at idle. The engine runs o.k and is full of oil. I am not sure I have the correct sensors as I seem to have three available wires (yellow, blue/white and blue/black) with two single spade connectors (black and white). Any helpful suggestions would be appreciated. Quote Share this post Link to post Share on other sites
hotoval1 0 Posted November 1, 2005 Sorry forgot to mention the car is a 1991 1.8 16V. Quote Share this post Link to post Share on other sites
Henny 0 Posted November 1, 2005 OK, I seem to remember that BOTH oil pressure switches are on the oil filter head on the KR engine (1.8 16V) and that the blue/white one is a spare, but I don't have my destruction manual with me at work so I can't confirm that... Anyone out there with a KR wanna have a quick look in their engine bay and let us know which wire goes to which sensor? 8) Quote Share this post Link to post Share on other sites
hotoval1 0 Posted November 7, 2005 Can anyone help? Quote Share this post Link to post Share on other sites
hotoval1 0 Posted November 16, 2005 Come on guys there must be someone out there who can advise on this problem. If you do not know the cure maybe you could at least tell me how the two sensors work with the oil light and bleeper. It must be simple but I just don't know what to try first. thanks Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 16, 2005 Earthing problems? Serious vibration causing contact problems on the sensor? Weird symptoms .. Quote Share this post Link to post Share on other sites
old man 0 Posted November 16, 2005 I have just been asking the same questions with a valver and reckon I have wrong sensors so hopefully these are the same answers for you black sensor 1.4 yellow wire and brown sensor 0.3 blue/black wire. Hope this helps Quote Share this post Link to post Share on other sites
2cc 0 Posted November 17, 2005 Just seen this and was gonna pop the bonnet, but looks like you now have the wiring answer. Come back if you're still having probs with her Quote Share this post Link to post Share on other sites
stickymint 0 Posted November 18, 2005 Hi I have a G60 with the same problem,oil light flashing,buzzer sounding,goes away after a few blips of the throttle.Oil pressure & level ok.Water ok. Help its doin my swede in. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 19, 2005 stickymint, Welcome to the forum... What oil are you using? Quote Share this post Link to post Share on other sites
stickymint 0 Posted November 22, 2005 Its now on full synthetic,but it used to do it on good mineral as well.Thanks for the welcome. Quote Share this post Link to post Share on other sites
white_vw_corrado 0 Posted November 23, 2005 i have this same problem - ive got a 1.8 16v - mine goes off when the engines cold or if i just over rev it. i was told to just replace the clocks as its a resistor thats gone. i never got round to doing this but i had an oil change and that sorted it for a while. i find if u just flick the ignition off and on it sorts it too Quote Share this post Link to post Share on other sites
stickymint 0 Posted January 23, 2006 There must be someone out there who knows what this is,or how to snip some offending wires Quote Share this post Link to post Share on other sites
Rob_B 0 Posted January 23, 2006 you shoulnt really run fully synthetic in a g60, but i would seriously look into this problem. the oil pick in the sump can sometimes get blocked causing low oil pressure. the sensor could be duff, or it could be something more serious as i found out Quote Share this post Link to post Share on other sites
Nick 0 Posted January 23, 2006 I know! I know!! Same things been happening on my '91 G60. Ive just been told i need to replace my engine. Get it looked by a professional asap. The pressure in my engine was basically non-existant once warmed up. I was advised to 'preferably' replace the engine, or at the very least a whole bottom end rebuild. Of course there are any number of solutions to your individual car problems, but its sod's law that i need to replace my engine. *edit - rob b seems to be familiar with this too!* Quote Share this post Link to post Share on other sites
Rob_B 0 Posted January 23, 2006 yeah im familier with all of this, i took the head off mine and no1 piston wasnt the shape it was supposed to be!! so hence my g60 is sitting in a workshop with no engine in! there is light at the end of the tunnel as i have a new engine and it should be a belter!! Quote Share this post Link to post Share on other sites
flusted 0 Posted January 23, 2006 it might be that your using the wrong coloured sender?different colours represent different pressures. I thought it was yellow wire to white swith and other to blue switch? Quote Share this post Link to post Share on other sites
stickymint 0 Posted January 23, 2006 Thanks for that.I'm thinking of changeing to different oil,(any Recomendations welcome).It already had new sensors but I'll try the pick up just in case. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 23, 2006 According to the Haynes Golf manual (for all models since 1987): Yellow: 1.8 bar (normally open) Blue/white: 0.3 bar (normally closed) Quote Share this post Link to post Share on other sites
stickymint 0 Posted January 31, 2006 Hi getting confused with the colours here,my G60 has a white switch on top of oil filter housing & a blue switch on oil line to charger,My Bently manual says black on filter housing brown on the other,can anybody clear this up. Quote Share this post Link to post Share on other sites
stickymint 0 Posted February 7, 2006 Hoorah,Cured my bloody beeping.Changed the oil to Magnatex and changed my oil pressure switch from white to black as stated in Bently manual.It had actually stopped beeping just by changing the oil.Make sure you get the right grade though. Quote Share this post Link to post Share on other sites
