-Neil- 0 Posted January 24, 2006 I have really bad cold starting problem and have been doing some searches on this site and have found some info on how it might be worth replacing the Blue or black or both sensors? I have a 2ltr 16v 1993 corrado. Can someone please enlighten me on these and what to ask for at GSF and where they are in the engine bay? thanks, Neil Quote Share this post Link to post Share on other sites
_leon_ 0 Posted January 24, 2006 blue sender reports to the ECU (from what i know), black is for your gauges. if the gauges are correct, just change the blue one. About 9 quid in total iirc from GSF inc postage. ask for the o-ring too which holds it into place in its bed. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 24, 2006 how do you remove the blue one? Quote Share this post Link to post Share on other sites
_leon_ 0 Posted January 24, 2006 disconnect the wiring harness that connects to the sender - pull out a clip holding it in place - and lift the sender out. at least thats on a G60 - not sure about yours but wont be too far different... and not sure where it is on a 2l 16v. Quote Share this post Link to post Share on other sites
flusted 0 Posted January 24, 2006 valvers are screwed in Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 24, 2006 It's completely different on the 2.0 16v, for a start it's not blue (it's white). It's on the flywheel end of the cylinder head and is a switch rather than a negative temperature coefficient sender. You can test the one you have with the aid of a thermometer, a kettle and a multimeter - definitely better than paying £28 for a new one un-necessarily....like I did. Here's a picture I found on the forum when I had the same question... Quote Share this post Link to post Share on other sites
Heardy 0 Posted January 24, 2006 Any ideas on what readings you should get when it's tested with a multimeter? Quote Share this post Link to post Share on other sites
rmn 0 Posted January 24, 2006 So on a 2l 16v engine loom whats mfa related? Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 25, 2006 so i take it the 'blue' sensor is the coolant temp sensor which is number #3 in the pic, and is it held in via a treaded bolt? PLease help. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 25, 2006 so i take it the 'blue' sensor is the coolant temp sensor which is number #3 in the pic, and is it held in via a treaded bolt? That's the one. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 25, 2006 Any ideas on what readings you should get when it's tested with a multimeter? If you're testing the 16v sensor then you're just checking that the switch changes state at a certain temperature. If you're testing a 'blue' temperaure sender than I'm not sure what the temperature/resistance relationship is off the top of my head. I'm sure the information is available, maybe in the Bentley manual. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted January 25, 2006 what would happen if that collent sensor was broken, how would i know, like irratic reving or lumpy idle or not a good start from cold? And how do i test the sensor, i have a multi meter. think Im getting closer to my probs! Quote Share this post Link to post Share on other sites
