belfastfumanchu 0 Posted July 27, 2006 Hopefully this isn't a dumb question to ask... I went round a roundabout really fast the other week, I mean way faster than I normally ever would, and a beeping warning type noise came from the dash. I tried doing the same thing tonight and it happened again ! Does anyone know what this beeping noise is ?? Anything to do oil pressure perhaps? The roundabout is kind of sloped on a hill btw. Quote Share this post Link to post Share on other sites
Jim 2 Posted July 27, 2006 Check your oil level... Quote Share this post Link to post Share on other sites
Mave 0 Posted July 27, 2006 Hey dude, check your oil, it usually does that... edit *shakes fist at Jim Quote Share this post Link to post Share on other sites
VR6 0 Posted July 27, 2006 It's an onboard driver aid. It tells you you're driving like a plum and should slow down ;) Quote Share this post Link to post Share on other sites
double-6s 0 Posted July 27, 2006 It's an onboard driver aid. It tells you you're driving like a plum and should slow down ;) No it's not. It's a minimum speed warning. You have to make it beep continually mate. :) Quote Share this post Link to post Share on other sites
NottsCounty 0 Posted July 27, 2006 It's an onboard driver aid. It tells you you're driving like a plum and should slow down lmao Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted July 27, 2006 Yeah like no one else on here ever went round a roundabout too fast ! First time it beeped at me in 2 and a half years ! Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted July 27, 2006 Your oil will probably be low and as it sloshes around when you corner hard the buzzer goes and a light IIRC - first time it happened to me I got such a fright I nearly crashed! :oops: Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted July 27, 2006 Cheers for the quick replies guys. :) Will check oil level tomorrow. Quote Share this post Link to post Share on other sites
kongo127 0 Posted July 28, 2006 This is why someone schrick developed their oil pans to prevent oil starvation on hard cornering. Of course, if your oil level is low you will still hear that beep. I have the VR6 voltage and oil pressure gauges on my car. When i hear the beep the oil pressure is very low! Around 0bar! Beware of that!!! Quote Share this post Link to post Share on other sites
Toad 0 Posted July 28, 2006 I have heard that if the sump has taken a knock the oil pickup pipe can crack, and will cause a lack of oil pressure on cornering despite the oil level being just right. Might be worth checking out if everything else seems cool. Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 28, 2006 That'll be the undocumented G-meter? :lol: Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted July 28, 2006 Yeah oil pressure sender warning you of immenant expensive damage... Happened to me coming off M25 and onto M11 long right/left/right corners Advised speed limit 30 (but can do it at 50) think the oil must have all been hiding in one corner of the sump by the time I came out of there.... But checked my levels when I got home and topped off the oil as it was a little low.... My Goof Cab did this to me about once a month and that had a fresh rebuilt engine, apparently, so well built it used 3 litres a month! :D Quote Share this post Link to post Share on other sites
chrishill 0 Posted July 28, 2006 your corrado is screaming, the only way it knows how. Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted July 30, 2006 Oil level was a wee bit bit low - really got to check it more often ! Live & learn. Ta again. Quote Share this post Link to post Share on other sites
