Twiss
Valver didnt want to come back to the IOW !!! -- Updated
Hello People
Went to alton towers over the weekend, drove up saturday morning then to the B&B and all was fine. Sunday morning arrived and got in the car and started the car , no probs at all.
But when I had to get off the boat to get back onto the IOW on sunday evening she really didnt want to start I had to turn her over while pumping the accelrater pedal, finally she then kicks into life, lumby at first but then settles down and idles normally, runs ok to. but ever since then every time she been left for more then an hour i have to start her like that.
The Fuel pump primes away.
The starter motor turns over ok
All mormal dash lights are on.
I've searched though the forum and I'm confused on what path I should take?
New fuel pump?
New injectors?
New switch?
sensors?
She's done 145,000 miles, 1990 1.8 16v
Could you point me in the right direction please?
Thanks Twiss
need to do a fuel pressure check first IMO
that way if it's not losing any fuel pressure you can start looking elsewhere.. definately getting a good spark?
If it losing pressure, like already stated it's more than likely an injector, had the same trouble as billinjah with the valve by the pump on my Mk1, only takes the smallest of crud to stop it closing and cause pressure loss
what's it like to start first thing in the morning?
first thing in the moring it takes a long time to start.
Turn key -- engine kicks over ----- turn key again engine kicks over then 5 seconds pass she will start and idle normally and run fine.
if I turn her off after she starts first thing in the morning or any time, I can turn the key and she will start first time and run ok.
Wheres the the fuel pump ? please don't say its in the fuel tank
I believe there's 2 pumps on the 16v, not done any work on my 16v's pumps yet
one will be in the tank, and the other will be by the rear drivers wheel
I'm sure someone will confirm
EDIT: the one in the tank is accessable from inside the boot
Well I just phoned VAG and they want £20 inc vat for the non-return valve is this right?
Is replaceing the non-return valve easy ?
I also thought I would change the fuel filter as i dont know when it was last done. Do I need any thing else when replacing the fuel filter?
Thanks for your help so far.
there's a good guide for changing the filter in the knowledge base. There's even a handy list of what parts you need. I just bought a filter, wish i'd bought a clamp for it too though.
Well I went to Change the non-return valve to day, Oh what joy. Simple job
As I went to remove the bolt that Holds the fuel pipe from the accumlator onto the non-return valve the fuel pipe would not let go of the bolt and decided to snap. At this point many many words of wisdom was spoken. LOL
So is the pipe that I broke a VAG only part or can I get it from another supplier?
The really bad thing is that I Have also found to day that number 1 injector seems to be wet but does not smell of fuel so it could be the problem with my starting!! I'll find out when it get the new pipe and put it all back together I suppose.
Thanks Twiss
Well After finally droping the fuel pump and all its bits off of the car I ended up replacing the non-return valve, the accumulater, both fuel pipes and the fuel filter. P
oped it back on the car and half a aturn of the key and she fires stright up. shes also running much better.
thanks for your help.
well looks like the above was to good to last
Well After replacing the fuel pipes, accumulator, non retun valve, Ignition switch, Dizzy Cap & rotor Arm(bought from unipart). she is starting better but is still 50% of the time not starting -- turn key-- engine kick over- nothing have to continue to kick the starter motor over while pumping the throttle and then she will start, lumpy at first but then runs and idles fine.
ANy ideas what else it could be ?
When you replaced the rotor arm, you didn't damaged the distributor did you? The reason I say that is when I replaced my rotor arm on mine I had to geta screw driver under it to leaver it off and bent the cylindrical bit inside slightly causing it to foul on the hall sensor inside the distributor. This gave intermittant issues with starting.
Worth a look?
Did you try changing the injectors?
Mine would run like a sack of sh!t to start with because the injectors were weeping fuel out. Got better when I changed them, although it's a pain in the arse to start at the moment... I don't think it likes getting cold... I'll have to buy it a jumper.
Hey Tom,
Does the C 16v's have a cold start injector like the Golf 16v does? Did you change that one as well? May be worth checking your cold start enrichment is working? Maybe I should stop asking so many questions? :scratch:
I decided to have the cam belt and tensioner all done aa I havent had done since i owned her and can't find out when /if she was done. if that dosent sort or serouirsly help her then I have to start thinking about injectoers, HT leads etc
thanks
Vaughn
