just_say_meth 0 Posted November 2, 2006 Right have mounted my cooler, ran the pipes, changed the water pipes to the mk1 versions, now just wondering what i need to trim down on the sleeve to make it fit the sandwich plate and oil filter?! Thanks in advance Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted November 2, 2006 Have you replaced the built in sandwich plate with a thermostatic one for the cooler ? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 2, 2006 What did you get in the kit and where from? - You need a part or two from a mk1 (no oil cooler) to fit Quote Share this post Link to post Share on other sites
flusted 0 Posted November 2, 2006 the bits i supplied you are to keep your existing heat exchanger,that way the oil will warm up to temp quicker and the cooler will keep it a optmium temp Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted November 2, 2006 Have you replaced the built in sandwich plate with a thermostatic one for the cooler ? Have replaced the original oil cooler for the mocal sandwich plate but am stuck there as i was told to cut down the centre shaft but not really understanding how? But have replaced the water pipes for mk1 items to bypass the cooler-supercharged Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted November 2, 2006 the bits i supplied you are to keep your existing heat exchanger,that way the oil will warm up to temp quicker and the cooler will keep it a optmium temp Darren at g-werks recommended to get rid of the it and just fit sandwich plate and oil filter. so already started on that. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted November 2, 2006 you will have a double threaded bit of tube, Cut one of the ends of at the bottom of the thread and then screw that into the plated fitting you have giving you thread on both ends. This then screws into the filter housing and the other end attach's you oil filter. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 2, 2006 ..Or you can just get the parts from a mk1 to save butting anything down Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted November 2, 2006 you will have a double threaded bit of tube, Cut one of the ends of at the bottom of the thread and then screw that into the plated fitting you have giving you thread on both ends. This then screws into the filter housing and the other end attach's you oil filter. So what i'll have will be about an 1 1/2" of thread and then i'll not need the thread with bit of blank tubing? Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 3, 2006 That's right. Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted November 4, 2006 ..Or you can just get the parts from a mk1 to save butting anything down Yep thats what I did. Mk1 GTI filterhead fitted to a 16 row mocal cooler. Whole lot of Ebay cost me £20. :D I removed the water based heat exchanger. I have no probs with the oil getting up to temp or staying there. I guess its first Winter will be the proof so to speak. Quote Share this post Link to post Share on other sites
