MNuTz
torque wrench needed
Hi all,
I need a torque wrench that is capable of the range 10nm to 25nm as ive got to change the fuel filter on my valver.
I dont want to spend the earth on something i will only use a few times at the most, any suggestions?
Thanks
Im going to change my fuel pump and filter aswell, i didint realise a torque wrench was needed. I was planning on downing a bottle of irn bru and using a ratchet.
25nm is barely tighter than hand tight, shouldn't worry about torquing it. Just apply common sense and don't ream the schitt out of a nut/bolt that obviously just needs nipping up.
well i was tempted just to tighten it, place a bowl under it and start her up, then just tighten by 1/4 until it stops leaking :D
Most of the 16v fuel unions use a light alloy washer and just need nipping up, in the past when I've fitted new washers re-assembling the system or re-used them (perhaps not the best idea) I've done exactly as you say and just nipped them up a bit more if they seep fuel, always been OK for me, always go back and re-check any fuel unions once the system is pressured up on the ignition and then when the car is started though!
that draper one is cheap for a low range wrench, wonder how accurate they are?
I use a cheepo one for wheel bolts but then a few NM either way isn't too critical there.
Yeah, no need for the TW, you get a new washer with the filter so just need to nip up...
Best tip for the 16v filters is to use a larger spanner (adjustable will do) to hold the filter while undoing the banjo bolts and be carefull not to move it much as the plastic lines are delicate when twisted
