JayGT
Braided hoses
Just got a Golf VR 288mm setup for my Corrado & need hoses. I know stealth do em (banjo fit) but are they the same as the ones sold in GSF?
Also what pads are recommended? No track days or anything like that just decent pads for the road.
Cheers
See thats what confuses me!!! Although i have Golf front brakes now, don't I get the Corrado kit?
DS2500, are they Ferodo ones? they were recommended by someone else actually. Are they available from GSF as well mate?
take it I need the Golf VR pads as well...
You do as they are considerably bigger than the standard Rado ones...
Excellent. Can't wait to try to these out... that is after my clutch, chains & valve stem seals are done :(
Talking of GSF and braided lines - does anyone know what brand GSF sell? is it defo Goodridge?
On the same topic there are two sets at the bottom of the gsf page
Which one is needed??
Ahh think ive got it i want the one 95> dont i??
99586A BRAKELINE KIT-BRAIDED G3 VR6 95> 6 Line 52.50 ??
Also do these fit straight onto the corrado then with that brakeline kit??
What the hell is a six line kit aswell?
Do these kits come with the banjo clips etc aswell??
Standard corrado brake fittings don't have banjos, they are screw in pipes.
True... but Golf 288's have banjos and that is what this thread is about :)
For some reason I thought the topic of conversation had moved toward standard calipers... Think it's just being stuck in an office by myself.
I think they do come with the banjos and the washers. But I know there has been some sort of discussion about the thread type and depth.
whats this about thread type and depth then??do i need different ones than the ones that come with the hoses??
Banjo bolts can be picked up for a quid or so each online.
They come in two different thread sizes - 1.5mm and 1mm.
Generally speaking, if you have early Mk3 callipers they're 1.5mm, if you have late Mk3 or Mk4 callipers, they're 1mm.
i think i would have a problem if i was doing a 312mm brake conversion but apparently i should be ok with the banjo bolts that come with the goodridge kit!
I notice from your signature you've got your 288mm brakes all set up. Just bought some of these off ebay and need to get the rest of the gear to fit them. Am I right in thinking I just need new discs, pads and Golf VR6 braided hoses? Or did you have to get some extra stuff to fit them?
Nope, thats all you need...
If you get a set of Goodridge for a 95 on Golf VR from GSF that should give you a complete kit for the car for £40 (with CCGB discount)
Just check the banjo bolts that come with the kit fit the calipers, if not go to a bike shop...
