Jim Bowen
Quick Question about brake discs
are they only held on by the wheel nuts?
is this normal? i can take a wheel off and then the disc is free to spin etc?
Nope should have one/ two screws holding them to the hub.. but main force is via wheel bolts running through discs and hubs...
Often screws are snapped come disc change time though.... One of my fronts has the same problem wich makes changing wheels a Royal PITA chasing the disc with a wheel bolt...
they are held on by the wheel nuts and 1 securing screw............chances are this could well be missing tho........but the disc will spin unless the car is in gear
i noticed a hole for a screw
can this be replaced, fecks knows where u buy 1 screw :lol: or 2 as its the same on both sides
PHEEEW!
I noticed this when i was changing the front pads. One side was ok, on the other side however the disc was free.
Im glad im not the only one.
Its just a locating screw which corrode badly and often break..
As vr6storm has said, stick it in gear and your laughing..
FWIW Ive had the screw missing on one of my discs for the past 5years.........never had a problem putting wheels on or taking them off
