vwdeviant
KR/9a hybrid?
Is it possile to sling a KR head on a 9a bottom end?
If so will I have to go K-jet rather than the current K-E-Jet (9a)?
Wondering, as I'm after a stage 2 KR head/cams for cheap and wondering if I can use it? If so what difference will it make?
Nice so just a straight forward head swap then?
Any ideas how I tell a "staged" head/ Fast road cams from a stock ones?
Also Can I re-use the 9a inlet/exhaust manifolds or do I need the KR ones???
Apparently an ABF Head Gasket is the best to use?
Yes
Difficult to tell, normally re-grinds
Yes
Yes
HTH ;)
There's something to do with fueling in KE-Jet along the lines of shutting the fuel off on over run so it doesn't damage the cat, K Jet doesn't. I think you'll kill the cat, and fail your emissions.
Better off buying an earlier car that doesn't need a cat and putting the 9A block in.
There's something to do with fuelling in KE-Jet along the lines of shutting the fuel off on over run so it doesn't damage the cat, K Jet doesn't. I think you'll kill the cat, and fail your emissions.
Indeed it does and it would.
"SNOT" Guru! Cheers Stuey! xxx :notworthy:
Fancy a head swap for Gooney tokens when you feel up to it?
That's a possibility. It would have to be done at OPO Euro-Tuning headquarters though. Can be done in a day as well.
Ahha! As it's a 92 I can just bin the cat! (Which was the intention once it died TBH!) and get £60 scrap for that! ;)
Stu OPO Euro Tuning's Workshops sounds fine!
depends what month in 92, CATs are required after august 92, i had an mot try to fail me for no cat untill i showed him the registration date etc....robbin bar-stool :nono:
