Bally
FK VR6 Coilovers fit my car?
Would they fit my 16v are are the spring ratings going to be different due the VR6 being a heavier car??
I thought that FK listed one kit for the Golf and Raddo VR's and another kit for the other variants?
just as an example the koni sports suspension kit is listed the same for all models so they must use the same springs,dampers etc..so i would think it would be the same with the coilovers
Hi mate hows it going.
It might be a good idea to invest in the coilovers if your going to get a storm next, you could buy two additional 16v spring to use on the coilover to match it to the 16v spring rate
koni only actually list one coilover set up across the whole mk3 golf anf corrado range so they will be fine
IIRC its only for plus suspension equipped Golfs that they list for
cheers for the replies guys...
Hey Maj, not doing to bad, just sorting out a few bits & peices on the car...
good idea about getting a set of spare springs, saying that, as long as the coilovers are in good condition is it ok to buy them 2nd?? I no I wouldn't be covered on warranty?
need to decide as I use the car daily & do alot of miles, which is making me think more to get new coilovers rather than 2nd ones?
Please advise!!
GOLF - MK1 GTI / SCIROCCO 1976-83 GTZ 800/801
GOLF MKII GTI & 16V / RALLY 1983-91 GTZ 810/811
GOLF - MKIII GTI &VR6 1991+ GTZ 815/816
CORRADO - 16V, VR6 1988+ GTZ 815/816
POLO 1994+ GTZ 820/821
taken from the avo web site,as you can see the part numbers are the same,all they would say is..if fitting on a vr6 use a slightly harder setting.. :p
Cheers Daz
So looks like the Golf MK3 runs the same part no's as the rado? anyone else confirm this?
I have just put my Golf Mk3 16v Koni Coilovers on my Corrado VR6 - same Koni part no
They are a straight fitment as all the chassis is the same
things are alright, just got to do some more bits and pices and put the wheels on but might do that after winters over
