mort1414 0 Posted August 8, 2009 just about to buy some new disks had a search couldnt really find anything on this subject is it really worth the extra 65 quid ebc are asking for a slotted disk over a plain one, http://www.ebcbrakesdirect.com/car/part ... 2899%2D%29 cheers mort Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 9, 2009 mort1414 said: just about to buy some new disks had a search couldnt really find anything on this subject is it really worth the extra 65 quid ebc are asking for a slotted disk over a plain one, http://www.ebcbrakesdirect.com/car/part ... 2899%2D%29 cheers mort are you running standard sized disks? how hard do you drive and on what sort of roads?, town/motorway mainly? grooved disks will tend to eat pads quickly compared to the same sized plain disks It really depends what you're after, maximum resistance to fade or the most positive feel in town with cold brakes Quote Share this post Link to post Share on other sites
mort1414 0 Posted August 9, 2009 im gettin 312mm disks for my brembos ,cars used as a daily( 90 mile a day )but gets driven properly at the weekends my 280s dont stand a chance at the moment i suppose i could get plain and see how i go as there only 40 quid cheere mort Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted August 10, 2009 Have you already run these bigger discs before? If so, then you can answer your own query - do you currently get brake fade? If so, then theres a good chance they're getting too hot and a drilled disc will help. Bear in mind that the 'cheap' discs are vented, just not drilled; drilled will run cooler - you might eat pads quicker. I'd be surprised if you need them. I see brembo 4 pots on big discs and these sized cars and they'll stop you on a penny, on a normal vented disc. If you've not tried these bigger discs before, then its hard to tell. IF you're in the process of upgrading, then I'd be tempted to go cheap for now and see if you like the new discs and pads and calipers, with new fluid (as said, they should do well). But you may end up paying twice if you dont like them and find they get too hot - nothing worse than boiling your hub; but I'd only expect this if you were hard on them, like being on a track. Quote Share this post Link to post Share on other sites
mort1414 0 Posted August 10, 2009 also is there any other bad points to drilled/slotted than extra cost and using pads faster cheers mort Quote Share this post Link to post Share on other sites
Toad 0 Posted August 10, 2009 Drilled disks often crack, especially the cheaper ones. I'd avoid them... Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted August 11, 2009 I'd get plain discs for the road and save the money for the next thing that goes wrong on the car (nb: Brembo disc never used to be bad) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 11, 2009 No, you don't need slots or holes drilled in your discs Quote Share this post Link to post Share on other sites
VR6Joni 0 Posted August 11, 2009 I've got a matched pair of mintex 312mm plain discs and pads without the brembos, and they are better by a country mile than my 280mm setup (EBC grooved discs and Pagid FR pads), no brake fade witnessed yet. However that tends to creep in with worn discs and pads (which mine aren't yet), also the elimination of the grooved disc grating is nice and pleasant. Quote Share this post Link to post Share on other sites
Mark_Storm 0 Posted August 28, 2009 Standard discs with Ferodo DS2500 pads. Went out round the Nurburgring in a VR6 Corrado last week with that setup on 280s and was really impressed. If you brake hard drilled discs can crack. Grooved discs will help prevent brake fade but will significantly reduce pad life so probably not great for a daily Quote Share this post Link to post Share on other sites
mort1414 0 Posted August 28, 2009 yh iv gone for plain as its a daily u got any pics of the ring stick em on :clap: viewtopic.php?f=17&t=83599 Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted August 28, 2009 Ive had groved and drilled,both are noisy...im going plain next for sure! Quote Share this post Link to post Share on other sites
