crazy-nige 0 Posted November 24, 2009 first of all hello everyone. Right the story goes like this. i am a vw person through and through although most of my VW's have the engine at the back, i always run a water cooled the rest of the time. anyway i bought my first corrado on saturday, This was a very cheap car with several issues. it is an ealy 1990 16valve. the main problem i have is that the car wont idle until the engine is warm(oil temp over 80deg) once warm it idles fine. It starts on the button providing you have your foot on the throttle slightly. i have cleaned and lubed the isv already with no sucsess, also the car seems to lack in power and when changing gear the revs take a while to drop off. it also seems to use quite a lot of fuel. i have already been searching through older posts but thought i would ask anyway. please help Quote Share this post Link to post Share on other sites
volksworld13 0 Posted November 24, 2009 more than likelt the dreaded coolant temp sensor, common problem on vw , temp sensor goes open circuit, the blue sensor in the plastic coolant housing.try this 1st :D Quote Share this post Link to post Share on other sites
crazy-nige 0 Posted November 24, 2009 will do. the temp guage still seems to work ok though or is that off another sensor? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 24, 2009 there's a lot you can check, correct resistance across the electrical connector on the warm up regulator, cold start injector, vacuum lines, throttle idle switch and so on. for starters ISV should measure 3.5 to 4.5 ohms across terminals warm up valve resistance (it has an internal heating element) should be 20-26 ohms to check control pressure of fuel from warm up regulator you need the appropriate unions and a fuel pressure test gauge, but after 2.5 to 3 mins control pressure should increase to 3.4 to 3.8 bar it should be about 1.7 bar on a cold engine with 20 degree ambient temp ecu temp sensor (small ones on side of head) should read 2,500 ohms at 0 deg C dropping to 100 Ohms by the time the engine is fully warm if you're happy the ignition side of things are all new/claen and operating correctly, I'd also check ignition advance and timing just so you know everything is OK idle CO should be about 1.5% Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 24, 2009 crazy-nige said: will do. the temp guage still seems to work ok though or is that off another sensor? there's no blue temp sensor like on 8v cars, the 16v has 3 identical sensors on the side of the head feeding gauge, ecu and idle control unit IIRC. Quote Share this post Link to post Share on other sites
crazy-nige 0 Posted November 24, 2009 thanks for the help guys. it proved to be one of the small sensors being open cicuit. car now idles lurvely cold or hot. just need to sort the emissions now where the previous :censored: owner has been fiddling. Quote Share this post Link to post Share on other sites
crazy-nige 0 Posted November 26, 2009 ok i've sorted the idle problem when cold. the problems i have are very high fuel consumption, what should i be getting from a 1990 (G) plate pre cat'd car. it also seems to be low on power, now i know i've only just got this car and its my first "c" but it definattely seems it. also it is still having dificulty starting when cold. please help before i sell it and go back to my bug. Quote Share this post Link to post Share on other sites
crazy-nige 0 Posted November 30, 2009 ok so far i have sorted the idle fault. checked and adjusted the timing to 6deg advance. set the emissions at idle to .5% but still i seem to be using a hell of a lot of fuel would you expect to get more than 100 miles to 3/4 of a tank. please any advice would be great as its costing a fortune to run. Quote Share this post Link to post Share on other sites
volksworld13 0 Posted November 30, 2009 you may have dribbling injector /worn injectors or a fuel leak.check around fuel filter for leaks and fuel lines ect Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted November 30, 2009 What sort of mileage you getting? Also where are you as we have a local guy who's a bit of a god with setting up K-jet... does it all by ear too! :notworthy: Quote Share this post Link to post Share on other sites
crazy-nige 0 Posted November 30, 2009 well there is definately no leaks so will check the injectors next i guess, but in all honesty it doesnt feel like a dribbly injector. now its pay day i will do a proper consumption test but to be honest it does seem to be a bit high. so far i have managed to get about 120 miles to 3/4 of a tank. basically my question is what sort of miles to a tank full do you get from your standard 16valve raddo's Quote Share this post Link to post Share on other sites
Reggit 0 Posted November 30, 2009 Sounds very low - does yours have the 12 or 15 gallon tank? My VR does 3-400 per tank depending on useage, so I'd expect you'd get more from a 16v if it shares the larger fuel tank. Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted November 30, 2009 early vavlver will have a baby tank... But still a bit low... you should be seeing 250+ from it! Best to whip the injectors out ans leak test them.. all 5 Quote Share this post Link to post Share on other sites
Skimask 0 Posted December 2, 2009 You should be getting around 350 miles to a tank on an early valver - -that's what I got from my one. That was with a duff deceleration valve. A couple of years ago according to the display - 36 -40 mpg. Quote Share this post Link to post Share on other sites
