nemesis360
ABS Brake pedal position sensor - DG Refurb service
Hi all,
We can now offer these as a refurbished part (due to VW making them obsolete) they are fully tested and come with a 12 month guarantee.
Send us your sensor and we will repair it and pop it back in the post to you the same day.
Refurb price is £49.95 inc vat and postage.
Thanks
DG Autotech
Where's the 'like this' button... oh yeah, that's facebook.
Will make do with :clap: then :)
Awesome guys this sort of service is just whats needed in the face of increasingly obsolete parts. :clap: Next job sourcing parcel strap replacements or manufacturers LOL
Great idea in the face of obsolete parts! :) Nice one guys!
I can vouch for this as the guinea pig for the refurbished part: so far, brill. ABS light now goes out and stays out as should do!
Well done Dave and Graham, another excellent DG service! :notworthy:
Hi all,
Thanks
DG Autotech
Very Good! Well Done Guys :D
Brilliant job.
Now if we can only find the supplier that makes the underbonnet foam 'waffle' pattern sheets so I can replace the stuff on my early cars..
Brilliant job.
I can stick some of these together and paint them black for you :lol:
SF13-0194.jpg?size=l
My valvers ABS light stays on but Ive replaced all the sensors, the garage couldnt work it out. What does the Brake pedal position sensor do?
Made from the same stuff aren't they? :lol:
Funnily enough it measures the position of the brake pedal...which tells the abs system how hard your braking.
If your popping in on saturday we can scan the codes for you FOC
Brilliant job.
Mmmn tasty..
I reckon this could be my ABS problem. Might have to bring the original rather than the VRT, my light stays on on first start then after about 20 mins if I then restart the car the light will go out and stay out :cuckoo:
I reckon I was car no.2. On having a shake down run following the chains and tensioners work the ABS light came on and it was traced to a brake pedal sensor issue. Hence I've been told they fixed this.
Hopefully I will find out this Saturday when I pick the car up.
That sounds about right.
Car looked lovely when I saw it at DG by the way. :salute:
D or G, can you drive the car without the sensor in situ? I guess so and the light will just stay on right?
i dont think you can as all vacume will be lost in the servo, and you have no brakes, some one to confirm this, i havent tried it, but there is a seal on the sensor/servo ,to prevent vacume loss.
