Rocket Ron 1 Posted May 21, 2010 My oil cooler seals are seeping oil anyone changed them and what is the process. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted December 20, 2010 Any one done the oil cooler seals info would be appreciated. Quote Share this post Link to post Share on other sites
Mawrick 0 Posted December 20, 2010 it's quite easy - although I haven't read thru this guide - it should give you a clue I guess :) http://passat.stoynev.us/maint/oil_cooler.htm Hope that helps! Quote Share this post Link to post Share on other sites
jamiehamy 0 Posted December 20, 2010 it's quite easy - although I haven't read thru this guide - it should give you a clue I guess :) http://passat.stoynev.us/maint/oil_cooler.htm Hope that helps! This link is good. It must be said, it's so much easier with the front end apart, but you can get it from below - ramps of some sort are a must. I applied gasket seal when i found mine leaking - never leaked since. I didn't have time to wait on VAG to deliver them as I was going away. Quote Share this post Link to post Share on other sites
fla 9 Posted December 20, 2010 its easy if you dont have the aircon pipes in the way :( thats why i'm leaving mine for eh summer. There are always downsides to every benefit on the Corrado. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 5, 2011 Thanks for the link, have printed off information. Will purchase seals etc and change them. :clap: Quote Share this post Link to post Share on other sites
easypops 8 Posted January 5, 2011 I replaced mine along with the seal for the oil filter housing.........took the front end off as access is limited.........easy enough to do though.........undo the big bolt in the middle , it slides out and the cooler comes away with a slight tap(something soft)......here is a pic of the seals with the part numbers, both of these are for the oil cooler btw, the one for the oil filter housing is a figure of 8 seal Quote Share this post Link to post Share on other sites
RW1 0 Posted January 5, 2011 viewtopic.php?f=1&t=45674&hilit=+cooler will help. . Quote Share this post Link to post Share on other sites
