daves16v
Judder - which mount?
I've had some clutch judder since I've had the car and I'm putting it down to engine mounts. Is there a specific mount that would cause this or is it a combination of worn mounts?
Thanks
Dave
or a contaminated clutch friction plate, have you had any oil or water leaks one the end of the 16v head?
He's got a VR now mate :)
I say engine mount as I'm also getting a jerk/thud when I lift off the gas.
Any idea how much a VAG gearbox mount is and is it easy to change?
Thanks for your help chaps.
IIRC it's about £60 for a gearbox mount new from VAG, not cheap considering you can get a Febi/Bilstein one from vwspares for ~£20. Don't get a GSF one though whatever you do, that's what I got before and it's foobarred in less than a year!
Not a massive job to do, just a bit of a ball ache. You need to loosen the GB mount and the front engine mount and then jack the engine up enough to be able to slide the GB mount out of the subframe. I find it's more easily accessible from the passenger arch (with the wheel off obviously).
Ok thanks guys, I'll go order one :)
Edit - just called VW - £79 inc vat
Edit again - that price was for the offside, GB mount is £54.50 inc vat so I've ordered it from TPS, collect Sat morning ready for the weekend.
Mine's doing the same thing- the gearbox mount is shot and leaking it's oil everywhere :( Have ordered a solid rubber MK2 Golf diesel mount from ECP for £20 :)
