ChrisFox 0 Posted August 12, 2010 I've been running a '91 16v 126K for about a year now, mostly motorway miles on it. However I've noticed that urban (nothing excessive in the rev's) driving seems to cause a lot of heat from the gear lever/trim, to the point where the stick is positively hot, and lifting the trim around shows the gear stick/linkage area is pumping out heat like a radiator. But if i then get on the motorway crusing in 5th, it cools right down to nothing. Is this normal?? Someone once told me they 'run hot'. Something to note is 3rd is getting stiff to select, somes requiring a fair amount of concentration to get right when hot. What might i be looking at here? Thought of getting the oil changed, as i dont think this has been done. Any comments or advise would be more than welcome! Quote Share this post Link to post Share on other sites
C488ADO 0 Posted August 12, 2010 matt changed his gearbox fluid recently and he said it made the world of difference to the selection of gears maybe have a look at that first? Quote Share this post Link to post Share on other sites
dukest 0 Posted August 12, 2010 they definitely do get very hot down the centre tunnel which obviously you notice in summer more than ever Quote Share this post Link to post Share on other sites
Jim 2 Posted August 12, 2010 Could be missing a heatshield down there? There are heat shields that run along the centre of the car and obviously you have hot exhaust running along there too.. without a heatshield there you're REALLY gonna notice some heat. Worth getting the underside inspected! Quote Share this post Link to post Share on other sites
ChrisFox 0 Posted August 16, 2010 Cheers guys, thats a weight off my mind- oil change will be order of the day. Was really not up for a new or referb'd box! Quote Share this post Link to post Share on other sites
coullstar 0 Posted August 16, 2010 Sounds like you have the heat sheilding missing from underneath. Unless the box is making some funny noises then I wouldnt worry about it. Quote Share this post Link to post Share on other sites
fla 9 Posted August 16, 2010 if you need it i've got a heat shield which I cut across the width into two pieces for easier fitting (slide in each section one from each end of the gearshift tower) Quote Share this post Link to post Share on other sites
joeyboswell 0 Posted August 16, 2010 I put mt90 gear oil in my vr and it drastically improved the gears. Quote Share this post Link to post Share on other sites
Album56 0 Posted August 16, 2010 The cat sits under there & gives off a lot of heat, heatshield may be missing. That darned cat! Quote Share this post Link to post Share on other sites
Jim 2 Posted August 16, 2010 Will say it again, as others have said - it sounds very much likely to be a heatshield. I think gearbox oil may be a red herring personally. Quote Share this post Link to post Share on other sites
joeyboswell 0 Posted August 16, 2010 heatshield isn't going to help his dodgy gear changes though. two problems and two possible solutions. get some good gearbox oil in and put a heat shield on. hopefully these will cure everything. Quote Share this post Link to post Share on other sites
ChrisFox 0 Posted August 17, 2010 It's too old for a cat, pretty much straight through exhaust; only realy noticed this since the summer, and like i said it clears up completely in top gear despite consistantly higher revs (which i find odd).. Garage had a good look over when the shocks were changed, didnt mention a missing heat sheild; I will try a 'box oil change for the time being and keep my fingers crossed on that. Quote Share this post Link to post Share on other sites
