VR6Pete 0 Posted November 29, 2010 My corrado has got 288mm front brake setup off a late Golf VR6. I'm after a suitable Goodridge brake line kit for mine, and my mate works for goodridge so getting them next to nothing. He says for my front 288mm setup I need kit SVW0604-06 ( VW Golf VR6 95 - on) which consists of 6 lines .... front / mids / rear... My question is, will the other hoses in that kit fit my corrado? I.E mid / rear with them being on the standard Corrado VR6 brake setup (1994 - L Reg) Cheers. Pete Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted November 29, 2010 No you can't, shame you can get a good price because otherwise this is what you need: http://www.dgautotech.com/dgauto/index. ... &Itemid=96 Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted November 29, 2010 I thought the ones off the golf would be ok? I've just stuck a standard set of hoses on mine from golf vr6 ut need banjo bolts still.. Why wouldn't rear / mids fit? Different lengths / fitments? Quote Share this post Link to post Share on other sites
dukest 0 Posted November 29, 2010 I'm talking 23 quid for the above. Dirt cheap!! I thought the ones off the golf would be ok? I've just stuck a standard set of hoses on mine from golf vr6 ut need banjo bolts still.. Why wouldn't rear / mids fit? Different lengths / fitments? not sure why Ollie is saying that, the 6-line kit for the late Golf Vr6 is exactly what you need (normally £70ish) but if you just want the fronts then DGs kit is your alternative yes. Quote Share this post Link to post Share on other sites
Mawrick 0 Posted November 29, 2010 Had some issuses with goodridge set myselfe - which was for the Corrado VR6: http://direct.the-corrado.net/.archive/forum/vie ... =goodridge If this will be the same trouble for you I don't know ;) Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted December 1, 2010 I spoke to Vince who confirmed the late Golf VR6 kit would suffice for my requirement as the mid / rear hoses on the corrado are the same as the golf :) Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted December 1, 2010 Well there you go, I stand corrected and learnt something :D Quote Share this post Link to post Share on other sites
