Philuk 0 Posted March 21, 2011 Goto car and sometimes it starts but sometimes just nothing. Ignition lights come on and then next turn there is nothing. Can't get into a pc so can't check and search properly but am I right in thinking it could be the ignition switch? Cheers! Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 21, 2011 quite poss, hopefully not the barrel to Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 21, 2011 It certainly sounds like the ignition switch, when or if has it been changed ? Quote Share this post Link to post Share on other sites
Philuk 0 Posted March 21, 2011 I've never changed it! I tried all 3 keys I have incase it was a worn key but to no avail! any ways of testing it? And are they easy to change? Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 21, 2011 switch is quite easy tbf Quote Share this post Link to post Share on other sites
mimjed 0 Posted March 21, 2011 if youve never changed it you might as well do it anyway. they dont cost alot. theres a wiki on changing them on here. no need to remove the seat though, just lie it flat. bend a small pozi screwdriver and its a 10 min job. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted March 21, 2011 I had a dodgy ignition switch mate it would turn the car over but wouldnt start it !!! My mechanic said it was making the wrong connections and turning the motor the wrong way wich in turn was making tjw car turn over but not start !! If thats possible anyway he changed it and its fine now but he did say he had to use a screw driver and hammer to knock the bolts round an out as they had some anti theft thing on them Dont know if thats any help but minea fine now after he changed it all Quote Share this post Link to post Share on other sites
mimjed 0 Posted March 21, 2011 hmmm only has one small screw to lock in place to my memory, certainly no need for a hammer! Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted March 21, 2011 Sounds like the ignition switch or factory immob. VW usually have the switch on the shelf (£20-ish) as it's the same as the Polo etc. Easy enough to change- the tiny screw is fiddly- you'll need a watch-makers screwdriver (or just one of those ones out of a cracker ;) ). Don't refit it- use a cable tie instead to save future hassle! There's a guide on here somewhere, but no point taking seat out and sorting it from underneath- easier/quicker from above IMHO. Do you have a factory immobiliser? If so, it's worth cleaning the plug with some contact cleaner or WD40. Just remove the driver's undertray and find the black cable with small black plug that connects to immob module. Unplug, spray & plug/unplug several times to clean. Worked on mine :) Quote Share this post Link to post Share on other sites
Philuk 0 Posted March 21, 2011 Think I'll give Vw a ring in the morning and get a new switch and five it a whirl Quote Share this post Link to post Share on other sites
swiftkid 1 Posted March 22, 2011 If you need a hand fitting it give me a shout, I swapped mine not long ago AND put the screw back in! Quote Share this post Link to post Share on other sites
gor123don 0 Posted March 22, 2011 Just purchased new ignition swich from VW dealers in Epsom. Had one in stock Pt. No. 6N0905865 cost £26.89 (£22.41 + £4.48 vat) and comes with a 3 year gaurantee so the salesman said. Quote Share this post Link to post Share on other sites
Philuk 0 Posted March 22, 2011 nice one dave. ordered mine from dealers today. think he said the same its £22-00 ish. gonna attack it at weekend i rekon! Quote Share this post Link to post Share on other sites
Philuk 0 Posted March 28, 2011 does they key need to be in the barrel to start the car.... it did it again tonight in sainsburys car park and i had the new ignition switch in the car so i took the cowling apart and plugged the new switch in. turned it so the lights came on and still nothing... surely it should of started but left my steering wheel locked? any other ideas. - quickly please! sposed to be going to gti spring fest on saturday and need it doing by then! - if not im gonna smash it up. o and the bonnet cable has given in aswell! joy! Quote Share this post Link to post Share on other sites
swiftkid 1 Posted March 29, 2011 Have you checked the earths in the engine bay? Mine had a problem starting a while back, checked the earth and it wasn't doing its job properly. Cleaned it up and it was fine. Is it happening everytime you start your car? In theory I guess that would work, but the immobiliser would cut in obviously after 5 seconds or so. What exactly is happening? Is it not even trying to turn over? Quote Share this post Link to post Share on other sites
quicky1980 0 Posted March 29, 2011 not sure if the key needs to be in the barrel, but I would have thought if you have a new switch you would be able to turn it with something like a screw driver. Try this http://the-corrado.net/showthread.php?53573-bypassing-ignition-switch&highlight=switch+bypass, worked for me when I recently had similar issues that redborbet had. Quote Share this post Link to post Share on other sites
Philuk 0 Posted March 29, 2011 Been out looking tonight and I think it's the starter motor +12v that's cone loose i could jiggle the wire about so I've tightened it up and just hope that's what it was. I put the new ignition switch in the same as I did last night and it started it up so that means it's not that because that didn't work last night. So this is the only other thing I can think it is. Got the bonnet open with 2 pairs of pliers. One held the clip on the cable and the other to pull the end of the cable and it opened . So Im seeing if my mate can make me one and could maybe get a few done if anyone else wants one? Quote Share this post Link to post Share on other sites
