STORM 2 0 Posted March 1, 2004 Does ANYONE know where I can get a replacement bulb for my key- you know the one you use to find the ignition in the dark. I have looked EVERYWHERE including VW and Maplin etc and have had no luck Its beginning to get on my nerves now Its a tiny 1.5V one Cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 1, 2004 If you can't find one on the net then it may be best just to get another key cut! Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted March 2, 2004 I am sure Kev H said he replaced his with a high intensity LED from Maplin. Its on my list of things to do and I bet it would give much better light 8) Quote Share this post Link to post Share on other sites
Bean 0 Posted March 2, 2004 Sounds loke a good idea!!! 8) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 2, 2004 I am sure Kev H said he replaced his with a high intensity LED from Maplin. Its on my list of things to do and I bet it would give much better light 8) I did on my old BMW key but I wasn't aware Corrado's had torch light keys? Get the dealer to list the parts used to make up a MK2 Golf 16V/G60 torch key as they use the same bulbs and I was able to get a replacement from the dealer...and a battery. Small Maglite torches use a similar bulb too, if that's any help. K Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted March 3, 2004 wasn't aware Corrado's had torch light keys? Mine has got one :? Quote Share this post Link to post Share on other sites
joebrent 0 Posted March 3, 2004 Mine aint got one either! :( anyone know when they were introduced?? Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 3, 2004 I think they were introduced 1994/5 and only on one of the two keys supplied Quote Share this post Link to post Share on other sites
VR6 0 Posted March 3, 2004 My Corrado key has a light and that's from late 92. Quote Share this post Link to post Share on other sites
andycowuk 0 Posted March 3, 2004 mine has one tourch key its early 92 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 3, 2004 Pics? I need to get one due to the poor street lighting in my area. Part numbers would be handy too please? And THEN I can I do my ultrabright LED mod :-) K Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 3, 2004 maybe it was dealer choice then....... Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 3, 2004 unless all original keys were torchkeys and have been replaced with others over the years Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 4, 2004 I think there the same as mk3 golf keys, like other parts the corradso got some mk2 then some mk3 Quote Share this post Link to post Share on other sites
VR6 0 Posted March 4, 2004 Pics? As requested :) Quote Share this post Link to post Share on other sites
stevemac 0 Posted March 4, 2004 These torch keys are readily available from VW dealers. I think my last one was around £13 (3 months ago). Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 4, 2004 any info on the led swap? what led do i need :roll: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 4, 2004 Excellent, cheers VR6. I'll speaking to the dealer tomorrow then! Steve, to do the LED mod, you need 2 x CR1623 batteries and an ultrabright LED, colour of your choice. The hole in the two plastic halves will need taking out to 5mm and the internals will need slight modification. My Bimmer key was almost identical to that and the mod was easy....when I get the parts and mod it, I'll post up the procedure. K Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 5, 2004 Hmmm...my dealer has 5 in stock but he said they're all transponder keys and non-transponder keys with Lights don't exist for the Corrado. That can't be right as some of you have the light keys without transponders......dealers....what do they know? Anyway, so what I'll do is just get the key and not bother having the transponder chip setup. Cheers K Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 5, 2004 have you seen the g60 /16v golf keys on ebay? i guess the dealer still sells em how do you get 2 batts in the key...and what voltage led do i need Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 5, 2004 have you seen the g60 /16v golf keys on ebay? i guess the dealer still sells em how do you get 2 batts in the key...and what voltage led do i need Ultrabright 5mm LEDs have a forward voltage of 2.4V, so you need two CR1623s to make 3V, which is fine for the LED. You just put one on top of the other. CR1616s will do and you can get them from Boots. CR1623s just have more current and are slightly thicker, so are better for the job. Standard key lights operate off one 1.5V cell battery. The internals of the key will need modifying. I've done it before and it's pretty straight forward, so I'll post a picture guide up in due course. K Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 6, 2004 are you sure cr1623 is the right number?? ive just found packs of 1616 's but no 1623?? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 6, 2004 Sorry, you need just one CR1623....they are 3V. A CR1616 or CR1620 will do the job. 23s are rare and will need to be bought online or in a camera shop. The higher the last two digits, the higher it's current rating, that's all. K Quote Share this post Link to post Share on other sites
stormseeker 0 Posted March 6, 2004 Sorry, you need just one CR1623....they are 3V. A CR1616 or CR1620 will do the job. 23s are rare and will need to be bought online or in a camera shop. The higher the last two digits, the higher it's current rating, that's all. K Strictly speaking the last two digits are the thickness of the cell in tenths of mm, i.e. 1.6mm or 2.0 mm in this case. Too thin and it might not fit snuggly enough in whatever holder it's been designed to go in... but yeah, bigger numbers do give bigger capacity ;-) And the first 2 digits are the diameter of the cell in mm i.e. 16mm :-) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 6, 2004 Yeah that's true.....forgot about that! The 23 is best as it's thicker but I've modded my key already and CR1616s, 20s and 23s all work perfectly :-) Pics to follow once the camera batteries finish charging! Quote Share this post Link to post Share on other sites
