Jim Bowen 1 Posted August 17, 2011 Is it possible to buy a complete set of clips for all the water hoses from anywhere other than VW. I imagine VW overcharge for them, i fitted a set of samco hoses a couple of years back and used jubliee clips, but never been too happy with them and would like to go back to the proper clips. Quote Share this post Link to post Share on other sites
captainredeye 0 Posted August 17, 2011 I have looked in the past with no luck so resorted to jubilee clips, would of thought a vw main dealer is worth a try! but if you find some let us know where. Quote Share this post Link to post Share on other sites
KipVR 1 Posted August 17, 2011 Scrap Yard! every time i go to one I take off all the little clips, hose clamps and loom guides plugs etc that i can find off the newer VW's. usually you get them dirt cheap too. Quote Share this post Link to post Share on other sites
ANDREW 30 0 Posted August 17, 2011 What about these: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290422214577&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_922 Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 17, 2011 What about these: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290422214577&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_922 Yep that's what I would use next time I need some. I've got one on my exhaust too. Quote Share this post Link to post Share on other sites
monzablau16v 0 Posted August 17, 2011 i ordered some mikalor clamps from this place: http://www.anyclamp.com/ look like good quality clamps. Here is the blurb for the W2: The W2 Series feature a corrosion resistant 430 Grade Stainless Steel Band and Bridge & a Silver-White Cr3 Zinc-Plated Tensile Bolt. Please See our Mikalor Supra W2 spec. pdf for more details - Click here High torque design for high pressure clamping. Beveled edges of band and bridge to eliminate damage to silicone / rubber hose. Swinging bridge for easy application with out the need to remove the hose 8.8 Tensile strength bolt Ideal for use on automotive boost hose, coolant hoses & clamping of exhaust slip over sections. Used extensively in Industrial Applications Size Range available 17mm to 252mm. or they do fully SS ones (W4) as well. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 17, 2011 i ordered some mikalor clamps from this place: http://www.anyclamp.com/ . excellent, just what i was after, thanks Quote Share this post Link to post Share on other sites
