Henny
Clear out
Having a clear out...
All parts are in Congleton Cheshire, or Salford Quays, Manchester if you want to collect.
All Corrado parts are from a '92 Corrado G60 with the early style interior...
Interior/Electrical
Prices include P&P
Corrado early dash center with vents, and drivers side vent/switch surround (great condition, with no broken clips) - £25
Corrado Window switch £5
Corrado Window switch surround (double) (x2) £5 each
Corrado Window switch surround (Single) £3 SOLD
Corrado Spoiler manual switch + Surround £10
Corrado Sunroof switch £10
Corrado Electric Mirror switch £7.50
Corrado Electric Mirror switch without knob (x1) £5
Corrado ABS Light £15
Corrado Cooling fan relay (ABS version) 1H0 919 506B £10
Corrado Indicator/Wiper stalks £15
Corrado C/L pump + Housing + Strap £20
Corrado Handbrake cover trim (Grey)£5
Corrado interior door pull (pair, black, early, slight damage to bottom where you lever them open) £5 for the pair
Corrado Rear View Mirror £5
Corrado early interior light (4 pin connector) - (x2, 1 has broken clips, the other is fine) £7.50 for the intact one £4 for the other one.
Passat B3 center sunvisor (above rear view mirror - clips onto Corrado sunroof motor cover) £15 SOLD
Corrado Sunvisors + clips (pair) £15
Corrado Coat hooks (pair) £5
Corrado G60 sunroof motor 357 877 795 £10
Gearbox bits
Prices include P&P
Gearshift weight (Cable change box) (x2) £10 each
Gearbox inspection bung £5 SOLD
Corrado G60 gearbox lower inspection panels 2 pieces £5 SOLD
Engine bits
Prices DO NOT include P&P
G60 Exhaust manifold £25
G60 Rocker cover - Aqua blue inc oil splash plate £15 SOLD
G60 rocker cover breather outlet (Square, not UFO) + pipe to connect to boost return £10
G60 ISV including both standard rubber pipes £20
G60 P/S pump £15 SOLD
G60 airbox to charger hose (x2) £15
G60 Corrado airbox (modified - Bottom cut to improve air-flow into box) £15
G60 starter motor excellent condition £40 SOLD
G60 starter motor slightly rough looking condition, but worked fine £30
G60 coil £15 SOLD
G60 dizzy + Clamp excellent condition £40 SOLD
G60 dizzy + Clamp rough looking condition, but worked fine £25
G60 side water flange (non genuine, but brand new) £5
G60 bottom metal water pipe (the one that feeds the radiator) £10
G60 block metal water pipe £10 SOLD
G60 P/S bracket 037 903 245 £7.50 (one SOLD)
G60 knock sensor (nearly new) £10
G60 C/O pot £10 SOLD
G60 Cambelt pulley (not sure which one) 037 109 111 £5
G60 cambelt top cover 026 109 123B £5
G60 Charger bracket 037 145 812 £10 (one SOLD)
G60 Charger bracket + tensioner arm + tensioner without pulleys £25 SOLD
G60 Charger top belt cover £5 SOLD
G60 Cam cover to Fuel rail brackets (pair) (x2) £5
G60 HT Leads (x2 sets) £10
Corrado G60 Charger to block support bracket £5
Brake bits
Corrado G60 ABS Servo + Master Cylinder 358 614 105 £25 (not inc. P&P)
Corrado G60 ABS Servo vacuum pipe including valve with both nipples intact £15
Other, none Corrado parts
Prices do not include P&P
Power Steering rack 1H2 422 061 £45
MKII 90 spec steering column surround (both pieces) £10
MKI Golf Zender 3 piece boot spoiler £65
Edited by Henny
Hello,
I'll take 2x window switches and 1x single window switch surround.. Hope you won't mind posting to Norway if I cover the extra fees..? :-)
Please PM me the payment details if everything's okay.
i'll take the spoiler with the brake light LED's ;-)
Wrong Corrado... :p
Hello,
Okey-dokey.... I'll dig 'em out tonight, find out the postage and PM you tomorrow... :)
Edited by Henny
do you have the first supercharger pipe from the charger to the intercooler bascially the first one behind the rad the rubber one mines rubbed though on the fan its straight off the bbm instead of the charger box sliencer i imagine there the same ?
James153? yup, I'm keeping the list as up to date as I can, so I know what I've got left! :lol:
There's still two available... want one (or two? ;) )
I'll take this please :)
Just the one please, dont suppose you have either of the front seats available?
Thanks james
nope, if it's not on the list, I don't have it... I'll drop you a PM with payment details in a mo'... :)
Is the sunroof motor working properly on tilt and slide? Is it an easy changeover do you know? Mines the usual tilt but no slide. Thanks.
Alex_G60_Fanatic, call it £3.50 P&P? Lemme know if that's OK, and I'll PM you payment details... :)
Sam.I, the motor is just a motor... if your roof isn't sliding, but is tilting both up and down, then it's probably the mechanism that's broken, not the motor, as the motor is obviously working in both directions to lift and lower the tilt.... There's a rather good guide on the forum somewhere that will show you how to repair this... I'll sell you the motor if you want, but I'm pretty sure you'd be wasting your money... 8) However, to test the sunroof motor is a doddle... flick out the interior light and undo the 2 screws underneath it which hold the housing up to the roof. Under it you'll see the sunroof motor, and it's held onto the mechanism by 2 large screws. Make sure you have the sunroof in the closed position before you remove the motor if you're going to swap it over, else you'll struggle to get it lined up again if you're swapping the motor. Once you've removed the motor, you can test it by simply plugging it back into the wiring without it connected to the mechanism. It should spin for a while and then stop when you press the button to raise the roof. It should then spin for a while and then stop when you press to lower the roof. If you then press and hold the lower button again, it should spin for quite a while as it would do while sliding the roof back, and then stop on it's own. Once it thinks it's opened the roof fully, you can press the raise button again and it should spin the motor as it would try to close the roof, and then stop back at the fully closed position. If your motor successfully does this, then it's the roof mechanism that's borked and needs repairing, not the motor. If it doesn't, then get back to me and I'll sell you the one I have which does do all of the above! 8)
sounds good :)
Sent from my iPhone you lemon!
"if it ain't on the list, I ain't got it..." nope, sorry...
How do Ian, interested in the below parts inc p+p...
Can you manage a pic of the servo vac pipe just so I'm sure it has everything I need? I'm actually just after the rubber end that fits onto the inlet manifold as long as it has no splits?
And would you be willing to sell the air box top (Cover) on it's own without the actual box (Lower part)?
Cheers, Neil.
Engine bits
Brake bits
Hi do you still have power steering rack (g60) and if so what's the condition( mileage) cheers Leigh.
