fla 9 Posted April 10, 2015 Thanks for the useful responses. I was also advised to leaving a weight or something similar on the brake pedal overnight for a few nights thereby keeping some pressure in the system. Would this actually do anything? If so I'm thinking how exactly to apply the pressure! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 10, 2015 Did you clamp open the rear bias valve? Quote Share this post Link to post Share on other sites
dragon green 5 Posted April 10, 2015 You can over bleed them,it puts a lot of micro bubbles in the system.I got mine close,drove it carefully for a week,re-bled it,sorted Quote Share this post Link to post Share on other sites
Jamie 1 Posted April 10, 2015 I had a nightmare bleeding my brakes but took the advice I got from John at JMR which was just drive it (carefully) and it did sort them out. What I did notice the last time was when I released the air on the Eezi Bleed to refill the brake fluid in the reservoir, it put loads of tiny bubbles into the fluid and I'm not sure if that was one of the causes of my headaches Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted April 11, 2015 That's why I recommend using a vacuum bleeder, it extracts air and doesn't force air out using air. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted April 11, 2015 I used a halfords pressure bleeder that uses air rom the spare tyre and that works fine. Quote Share this post Link to post Share on other sites
