JJS
Glovebox bulb
Anyone got a spare glove box bulb i can purchase?
Jon
Did you have the same trouble as I did trying to find a pack of 1 or 2?
Not done a lot of research so far but not found one in the normal shops so possibly i have to buy one online or off someone who has a spare.
I guess its not that easy to get one then Dave?
Couldn't get one anywhere! Ended up a dealer job, think i ended up paying a few quid... Should have just gone dealers with all the time I wasted tracking one down and with the wasted fuel running to local motor factor shops! Not even gsf or ECP had any...
little 3W bulb, just order an LED equivalent off e-bay they're much brighter and whiter so you can actually see things at the bottom of the box, just make sure to get one short enough 25-30mm is OK I think.
or this if you want original:
http://www.ebay.co.uk/itm/Motorcycle-SV7-8-12V-3W-FESTOON-30mm-LONG-bulb-/120800573376?pt=UK_Motorcycle_Parts&hash=item1c204677c0#ht_1985wt_181
or 1W single superbright LED, I've got a twin version of this for the boot which lights it very well, slightly directional http://www.ebay.co.uk/itm/31MM-1w-SMD-HIGH-POWER-LED-NUMBER-PLATE-LIGHT-FESTOON-BULB-XENON-WHITE-ALUMINIUM-/290626713586?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43aab3b7f2#ht_2975wt_990
or this one:
http://www.ebay.co.uk/itm/2x-31MM-INTERIOR-LIGHT-FESTOON-BULB-LED-XENON-WHITE-UK-/300593398258?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45fcc341f2#ht_2959wt_990
Edited by davidwort
I ended up buying a pack of 10, gave some away to friends, got about 6 left. I can post you one but David's Ebay suggestion is just as good.
Thanks for the offer Dave and advice David. I will check those ebay links later today when i get a moment.
