OllieVR6 0 Posted September 30, 2012 I have ordered a new rad and want to make sure that I have all the extra parts before I start. I'm going to order an elbow from classic parts, does it come with the O ring? If not, do VW still sell them? I think I'll also get a new fan plug thing (the bronze bit). Is there anything else I'll need? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted September 30, 2012 (edited) Depends how far you want to go. My next project is to replace: Rad + elbow Fan switch Crack pipe Stat housing + sat + sensors + all seals Change expansion tank for MK4 expansion tank + plug Silicon hoses Maybe heater matrix *Edit* + water pump! Edited October 1, 2012 by CazzaVR Quote Share this post Link to post Share on other sites
Philuk 0 Posted September 30, 2012 ive got a rad sat downstairs and will be changing, Rad + elbow Crack pipe. fan switch and hoses. gonna look into the mk4 expansion cause i quite like the look of it! is the stat housing a weak point. i had a new stat a few years ago like Quote Share this post Link to post Share on other sites
Fine wine, Belgian chocs. 1 Posted October 1, 2012 The rubber seal for the elbow is a fairly standard sized rubber o-ring. If you get stuck for one then PM me and I'll send you one. Quote Share this post Link to post Share on other sites
fendervg 32 Posted October 1, 2012 I has lots of problems on my MkII because I was replacing bits of the cooling system piece meal - what tended to happen was that when you replaced one old part, e.g. the water pump the pressure in the system would rise and spring a leak somewhere else. If I was to do it again I'd just renew the whole system at the same time - you will have it drained anyway. So I'd recommend saving, and doing: Rad Temp sender Stat housing and stat Water pump if noisy Hoses Crack pipe Oil cooler Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted October 1, 2012 Ok thanks folks. I can't stretch to new hoses but I can probably manage the rest. I replaced the matrix a couple of years ago so that shouldn't need doing either. I'll be getting the water pump out to check it whilst I'm in the bay, are they expensive to replace? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted October 1, 2012 New rad from VW comes with the elbow already fitted btw Think the water pump is about £50-60 and is an exchange item (return your old one) I also ended up doing everything on mine as it kept bursting in new places, rad, thermo housing, pipes all went within month of each other. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 1, 2012 Not the O ring on the below is a flat profile not a round profile. Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted October 1, 2012 New rad from VW comes with the elbow already fitted btw Think the water pump is about £50-60 and is an exchange item (return your old one) I also ended up doing everything on mine as it kept bursting in new places, rad, thermo housing, pipes all went within month of each other. I didn't get a VW one (obsolete or so I thought) I got the Hella one that Pete has been saying good things about (and that Dave has been using for 30k odd miles). Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted October 1, 2012 Defo do the water pump! Quote Share this post Link to post Share on other sites
Fine wine, Belgian chocs. 1 Posted October 1, 2012 Not the O ring on the below is a flat profile not a round profile. The o-ring on the elbow is a flat profile not a round profile? You're probably right. But the original one is apparently obsolete now at VW so I had no choice but to use a standard o-ring which fitted a treat and sealed perfectly. Unfortunately I had to buy a huge selection box from Screwfix to get the right size so I've got one or two spares now. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 1, 2012 Yeah i did that once as a quick fix. Bought some from B&Q and it seaped, so you did well to get it to seal. That was meant to say note* and elbow* btw.... :lol: took quick to type Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted October 3, 2012 Temp sender Is this the same part as the fan switch? Quote Share this post Link to post Share on other sites
