krishen
Door membrane seal
I've used garden black thick foil cut to measure by myself, cheap and easy to do, then use flexible sikaflex sealant, same as used in motorhomes. All together available for about 10 quid from ebay.
SUPERCHARGED have U got the part no for it?
I tought its obsolet now
If you mean the sealant,it's still available as its not Corrado specific
I'm sure the membrane is obsolete,I bought mine from e-bay
The membrane is obsolete now, they sell a foam replacement which is just as good, but you have to cut it to shape yourself.
I got some of ebay for my Mk2 golf, can't remember who from but i recall they did several different ones. search it under mk2 and see if it comes up. but it is essentially just a sheet of plastic that perhaps B&Q etc should sell.
I used regular spray on auto glue which worked a treat too.
