Hofmiester 10 Posted February 25, 2013 Hi guys, Ever since I bought my car last year, I have had the odd ABS light on situation. This has gotten more and more frequent until now it is just on all the time. I used VCDS to read faults and it was saying that all the sensors are reporting bad readings which suggested to me it is a connector issue. Pulled the connector today to find 2 wires broken and several look to have been Chewed? Any ideas on how I can fix this as break point is almost flush with the connector and so no wire left to re-join :( Quote Share this post Link to post Share on other sites
nrc 0 Posted February 25, 2013 Can you prise the blade terminals out of the connector with a miniature screwdriver? If they'll come out it won't be too tricky to cut back the broken wires and replace with new terminals. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted February 25, 2013 Unlike most connectors on the car, the back of these seems to be filled with some kind of Epoxy, probably to stop water ingress. It looks a right bitch to fix this one! Quote Share this post Link to post Share on other sites
Jim 2 Posted February 25, 2013 Can you cut one off a breaker with a bit of spare cable and just join them together - properly solder the connections and then protect each one with heatshrink and then wrap over with loom tape. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted February 25, 2013 Hi Jim, yeah I think that is my last resort although I was hoping there would be a less severe fix. Does anyone know if driving with this cable disconnected would cause any issues? I ask as MOT on my car is not due until MAY and so it gives me some time to find a breaker to get the connector from. Should I disconnect a sensor so that the ABS control unit shuts the ABS down? Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted February 25, 2013 I think Jims is the best approach to be honest. Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 25, 2013 I'd take out the abs relays rather than fiddle with connectors in the engine bay to disable the abs, they're nice and dry under the dash (passenger side.) Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted February 25, 2013 I'd take out the abs relays rather than fiddle with connectors in the engine bay to disable the abs, they're nice and dry under the dash (passenger side.) Hi David, I read on the Vortex that the power to the ABS also is linked to a few other systems in the car. I also read that disabling the power to the ABS also takes out the brake booster and so makes the brakes super crappy.....not sure in how much trush there is on the Vortex though ;) Quote Share this post Link to post Share on other sites
vw rule 19 Posted February 25, 2013 You could try and purchase a new wiring loom as most of them are still available at WV main dealers, I bought a new loom for my Corrado, the head light switch loom as the wires had burnt due to a short, it cost me around £80.00 for the new loom from VW. But yeah I'd say your best bet is to get a second hand loom or connector plug and do it that way as Jim has said, a lot of the wiring looms are on Ebay. Si :thumbleft: Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted February 27, 2013 Managed to score the end of the ABS looms from a local breaker.....along with some other goodies ;) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 27, 2013 I was given a tip when splicing together two bit of loom like that, and it was to stagger the joins so you don't end up with one big thick clump of joins at the same point on the wire. may be obvious but i didn't think of it, so passing the tip on Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted February 27, 2013 Cheers Jim, a very good tip! Time to fire up the old soldering iron :) Quote Share this post Link to post Share on other sites
vw rule 19 Posted February 28, 2013 Oh cool yeah that's it mate you should be all sorted now. Si :thumbleft: Quote Share this post Link to post Share on other sites
