VWVW 1 Posted May 17, 2013 Anyone had this before ?? Noticed the steering wheel recently have developed a sanding sound when I turn my steering wheel left and right. Quote Share this post Link to post Share on other sites
carrots 1 Posted May 17, 2013 mine always done it Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted May 17, 2013 It's rubbing on the steering column cowling... Otherwise there could be something sinister going on! Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted May 17, 2013 Take the wheel off , get a dremel with a polishing bit on and buff it with brasso , then give it a good polish with metal polish then cover it in vaseline and hey presto you have another 20 years before you have to do it again lol , i guarentee that wil work if not il eat my hat ---------- Post added at 9:01 PM ---------- Previous post was at 9:00 PM ---------- Ohh forgot also polish the little brass connector that touches the ring , you will see it wen the wheels off Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted May 17, 2013 What this man said^^^^^^^^^^^^^^^^^ Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 17, 2013 I just rubbed a credit card in the gap and made it go away. Can sometimes be the horn thing Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 18, 2013 It'll be a bit of grit on the indicator cancel mech. As mentioned, take the wheel off and wipe round the ring and all will be well again! Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 18, 2013 Thanks for the suggestions I will give them a try later. Quote Share this post Link to post Share on other sites
joeypineapplez 0 Posted May 18, 2013 Just sorted mine recently. Had the same sandy noise you described. It turned out to the little brass arm that makes constant electrical contact with the wheel. You will know what I mean when you remove the wheel. The brass arm gets worn and developes sharp ragged edges which make the sandy scrapping noises as you turn the steering wheel. Simply file it smooth again and all will be well. Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 18, 2013 Yeb...it was the little brass arm. Gave that a clean with contact cleaner and noise was gone. Thanks all. Quote Share this post Link to post Share on other sites
