Adam_sky 10 Posted August 13, 2013 As title, in need of a pair of rear brake carriers for the VR6. I'm stating VR6, because i'm unsure if other corrado models use the same at the back. Siezed and rounded carrier bolt leaving me with only two options. Replacing the carrier(s) is one. Thanks. Quote Share this post Link to post Share on other sites
Dox 22 Posted August 13, 2013 http://www.vwspares.co.uk/corrado_brakes.php They're not too expensive new. They're the same as Golf MK2 / MK3 and all Corrado rears are the same Quote Share this post Link to post Share on other sites
dragon green 4 Posted August 13, 2013 (edited) Beaten to it £18.90 each Edited August 13, 2013 by dragon green Quote Share this post Link to post Share on other sites
perky15 0 Posted August 13, 2013 If there the same as mk4 rear carriers i have a pair you can have for £5+ postage? Ill even throw them in the blaster so there clean :-) Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 13, 2013 If there the same as mk4 rear carriers i have a pair you can have for £5+ postage? Ill even throw them in the blaster so there clean :-) Mk4 carriers have a different pitch. so don't fit ! Re:- seized carrier bolts just done mine this afternoon soaked in WD and plus gas then used erwins to get them out.... worked a treat the new carrier bolts are about 3 squid each from VW as they are hi tensile. Quote Share this post Link to post Share on other sites
