corradlo 0 Posted November 19, 2013 (edited) Gents, I know this has been asked a few times and i have looked at some posts in relation to this, but im not clear on the answer. Basically im building a throttle bodied abf, and im on a mission to clean and rebuild the fuel system, so i would like to use just the in tank pump from a vr. This is so it is a simpler system, and i can easily access it from within the car if need be. will a vr6 tank actually fit my early 16v body. I would like to get a complete setup from a vr, so just need to know if the tank will physically fit. Thanks in advance. Edited November 19, 2013 by corradlo mis spelling Quote Share this post Link to post Share on other sites
dragon green 4 Posted November 19, 2013 If you have the smaller tank the later wont fit ! Unless you want to cut out the boot floor and weld in the later one Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 19, 2013 what you need to check is the fuel pump mounting inside the tanks (or the base of the pump/lift pump), to see if the early small tank 16v/G60 will accept the VR6/2.0 8v pump, I suspect they will as the late 2.0 16v with the bigger tank used the early style 16v lift pump and external pump. There's a plethora of tanks though, something like 8-10 different ones across the models and years. Quote Share this post Link to post Share on other sites
corradlo 0 Posted November 19, 2013 Thanks for the quick replies guys, so just to clarify, a vr6 tank will not fit the early body. I was under the assumption that the single pump tanks had a larger opening for the pump itself. Anyone know if it's possible to use any mk3 bits to convert my car to a single pump? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 19, 2013 I have a mk3 VR6 pump in my 2L 8v, only difference is the shape of the float arm which I had to bend a little to get the right reading on the 70L corrado tank, possibly because the golfs all use a 55 litre tank. looking at the chassis numbers the tank screw cap seems to change part number with the fuel tank change from 55 to 70L, so as well as the bottom fixing in the tank you may need the to make sure a late pump top part fits the tank opening, that might stump you fixing a late pump into an early tank. I've got both 55 and 70L cars so I'll check under the carpet if I remember! also have the old 2L pump so I'll try to take a pic of the bottom fixing. Quote Share this post Link to post Share on other sites
corradlo 0 Posted November 20, 2013 Will a 2.0 8v tank and pump fit? i will fit whichever tank mates up to one of the single pumps. The car is a bare shell at the moment, with only my existing tank on there, so access to change is easy, hoping i can come up with a solution before i start to re assemble the rest of the car! Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 20, 2013 (edited) I assumed the 8v was a 70L tank (which wouldn't fit an early 55L tank car) as it's a later car with the raised boot floor, but the other day with it close to empty I only got 50L in it ??? ETKA does only specify the one tank though (70L) for the VR6 and 2.0 8v, so it must be a 70. Actually, checking the part numbers, the KR (1.8 16v) and G60 share the same 55L tank (PN: 535201075H) but they also share the small in tank lift pump, what you probably need is a mid production G60 tank (PN: 535201075M) which is 55L but uses the full size single in tank pierburg 4 bar pump (chassis no, 50-L-005 733 >> 50-M-035 000) Edited November 20, 2013 by davidwort Quote Share this post Link to post Share on other sites
corradlo 0 Posted November 20, 2013 So there were some g60's which had a 55ltr tank with a single pump?! that would be perfect, i will call my local vw dealer to check and see. failing that i guess i will have to source one second hand! some great info there david. Quote Share this post Link to post Share on other sites
Dox 23 Posted November 20, 2013 (edited) I suspect I have the tank you're after, but I'm a long way from London and couriers wont carry a used fuel tank and I wouldn't want to courier it anyway TBH I replied to your PM, the tank is still in the car, Hennys old G60 shell. Edited November 20, 2013 by Dox Quote Share this post Link to post Share on other sites
corradlo 0 Posted November 20, 2013 I checked with a dealer today and it looks like to tank is not available anymore :(, does anybody have one that is off a car already, with or with out the pump? or could somebody post any pics of what the large fuel pump looks like inside the boot floor, to help with my search!! Thanks gents Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 20, 2013 This might help but the images seem a bit corrupted, might have to reload them, post #117 http://the-corrado.net/showthread.php?t=12282&page=12 Quote Share this post Link to post Share on other sites
Dox 23 Posted November 26, 2013 Tank pics Base of the pump Bayonet at the base of the tank (with and without flash) Quote Share this post Link to post Share on other sites
corradlo 0 Posted November 29, 2013 Thanks for the pics, the tank number one is very helpful, will definitely help with tracking one down... Quote Share this post Link to post Share on other sites
