Kempy 0 Posted March 12, 2014 Afternoon Fitting my coilovers at present. 3 down one to go. The rear right side is causing me a issue. The bottom bolt is loosened but not coming out, it's not snapped I don't think as I can feel the end of it spinning. Any ideas? Or what can I do? Thanks Quote Share this post Link to post Share on other sites
paddy26 3 Posted March 12, 2014 Try put a jack under it to take the weight of the axle off the bolt. Quote Share this post Link to post Share on other sites
Dox 23 Posted March 12, 2014 It could be the bolt is seized into steel bush is rotating inside the rubber part of the bush? Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted March 12, 2014 (edited) Think Dox may be right, can't see any other reason for it. You could try screwing the bolt from the other shock in to the nut from the back to try and push it through. Or lump hammer and thin bar/screw driver/drift it out. Edited March 13, 2014 by VR6 Gar Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 12, 2014 You might need to get a nut splitter on it... Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 12, 2014 The nut is a captive one by the way. Won't spin as its part of the axle. If you have an eletric wrench you can try spinning the bolt while levering it outwards with a screwdriver. Definitely helps taking the weight of it. Disconnect both rear shocks at the top and you can jiggle it while trying the bolt. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 12, 2014 Plusgas always helps me as well. Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 12, 2014 sorted, I didnt know it was simply a nut on the inside, I thought it might be welded or part of it. I stuck a spanner on it and got it off lol. Dont remember the job being so much of a pain. The side with the tank on was such a pain to get out and then back in! arrrgggghh.. done now that got. well low now haha Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 13, 2014 Oh right. Mine didn't come off so I thought it was welded. Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 13, 2014 its held on with a bit of metal that clips on. Quote Share this post Link to post Share on other sites
