Ray1965 10 Posted March 26, 2014 I'm wanting to spruce the engine bay a little. Would like to know what the best kind of silver spray to use. Does it have to be heat resistant? or can i use normal paint? I'm going to be painting the manifold, and then the plastic rocker cover as well. Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted March 26, 2014 Hycote vht silver spray, used on mine. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted March 26, 2014 (edited) That looks a good job. How hard is it to remove the manifold? Are there any gaskets etc to change if taken off? Looks like it could be done still on the car. With a bit of masking off. Edited March 26, 2014 by Ray1965 Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 26, 2014 There are two pieces to the intake Ray, an upper and a lower. Little bit fiddly getting the bolts out but not too difficult. It's all monkey see monkey do. There are two metal gaskets, one between upper and lower, and one between lower and block. These are metal gaskets so provided they're not too corroded, a bit of gasket sealant will suffice. Either way they're not too expensive to replace and are quite readily available. There's a paper gasket for the throttle body though, which I'd recommend you replace if you take it off. As for the lower part, you can't remove it without removing the injector rail, but it can't really be seen when everything is in place, so I'd just do the upper if your not going balls out mate. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 26, 2014 Alumablast! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 26, 2014 http://www.frost.co.uk/eastwood-aluma-blast-paint.html Quote Share this post Link to post Share on other sites
fla 9 Posted March 26, 2014 just did my spare manifold in Halford high temp paint with a coat of lacquer on top to give it some shine. Will be fitted with the OBD2 conversio (temporarily)... Quote Share this post Link to post Share on other sites
Ray1965 10 Posted March 26, 2014 (edited) Cheers for the info guys. Using HT paint looks like the best option then. Probalby will go for leaving the manifold on the car and masking everything, for the quick option. Edited March 26, 2014 by Ray1965 Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 26, 2014 I've had mine powder coated. Looks pretty good still after a couple of years Quote Share this post Link to post Share on other sites
Hula 10 Posted March 27, 2014 I sent mine off for vapour blasting, looks amazing like new and it's been over 6 months now and still looks the same. Upper, lower inlet and cam cover was all done for £50 Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted March 27, 2014 I sent mine off for vapour blasting, looks amazing like new and it's been over 6 months now and still looks the same. Upper, lower inlet and cam cover was all done for £50 How have you maintained the finish? Quote Share this post Link to post Share on other sites
Hula 10 Posted March 27, 2014 No need as they put some chemical in the vapour to stop it oxidising Quote Share this post Link to post Share on other sites
fla 9 Posted March 27, 2014 Would you mind posting some contact details of where you had them done? Quote Share this post Link to post Share on other sites
Hula 10 Posted March 27, 2014 It was R D Cox and Sons in Reading Quote Share this post Link to post Share on other sites
Ray1965 10 Posted March 28, 2014 (edited) Hula, That looks great. No paint or protection applied you got me thinking now :scratch: Edited March 28, 2014 by Ray1965 Quote Share this post Link to post Share on other sites
Ray1965 10 Posted April 8, 2014 (edited) Think i'm going to go with the Hycote vht paint, and a coat of clear to finish it off. Also going back a post or two on the thread, will it be possible to spray on the car? Edited April 8, 2014 by Ray1965 Quote Share this post Link to post Share on other sites
Hula 10 Posted April 8, 2014 The problem with VHT paint is that it doesn't really dry until it's really hot or left for a long time Quote Share this post Link to post Share on other sites
bruny 0 Posted April 8, 2014 Think i'm going to go with the Hycote vht paint, and a coat of clear to finish it off. Also going back a post or two on the thread, will it be possible to spray on the car? Hi Ray, You will struggle to make a job of it without removing, I would sandblast and treat with wd 40. Easy to maintain, and it will not crack peel or flake. If you are going to Elsacar I will show you the finish on mine which has been done for some time now. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted April 9, 2014 Hi Ray, You will struggle to make a job of it without removing, I would sandblast and treat with wd 40. Easy to maintain, and it will not crack peel or flake. If you are going to Elsacar I will show you the finish on mine which has been done for some time now. Ok Bruny, cheers for the info, Yes i will be at Elsecar show, car will be on the CCGB stand. :thumbleft: Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted April 9, 2014 I've had mine powder coated. Looks pretty good still after a couple of years this gets my vote too!! Quote Share this post Link to post Share on other sites
Ray1965 10 Posted April 15, 2014 Painted mine for now go to this post for a look. Page 464 http://the-corrado.net/showthread.php?t=14207&page=464 Quote Share this post Link to post Share on other sites
StueyB 0 Posted April 15, 2014 Powdercoat gets my vote and really doesn't break the bank. Super durable and if done correctly will last years. Fanny-molds were blasted and spray something like 5 years ago. Charger outlet about a month ago. [ATTACH=CONFIG]78310[/ATTACH] Hard pushed to tell the difference. Quote Share this post Link to post Share on other sites
fla 9 Posted April 15, 2014 Painted mine for now go to this post for a look. Page 464 http://the-corrado.net/showthread.php?t=14207&page=464 Looking good. Any pics of the calipers (before and after)? Quote Share this post Link to post Share on other sites
Ray1965 10 Posted April 15, 2014 Cheers Fla, I'm afraid i was that busy, i forgot to take some pics of the calipers. :bonk: They come up ok 100% better now. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted April 16, 2014 Hi Ray, You will struggle to make a job of it without removing, I would sandblast and treat with wd 40. Easy to maintain, and it will not crack peel or flake. If you are going to Elsacar I will show you the finish on mine which has been done for some time now. And that finish is otherwise known as....... mint! See you at Elsecar Dave :) Quote Share this post Link to post Share on other sites
