Dox
280mm rears
I was following this at first but at £65 plus post for a pair of spacer plates plus two old disks I'd not use, it has gone beyond what I was willing to pay!
Need some info on what part nos. and I might order them from TPS.
There was a group buy on here 5? years ago, I think they're Eurospec discs (not VAG) and are around £200 for the pair
What are the discs off? May do this myself next winter.....
The discs are "one offs" by Eurospec
John(16vG60)does do a 280 vented disc conversion,but this doesn't fit under a 15" wheel like the Eurospec
Yep, they're f*cked... you'd want new discs, bearings and ABS rings so all you're paying for is those spacers and postage.
Vented conversion is the way to go I reckon!
If doing the 280 rear setup are people changing to a adjustable rear brake bias or sticking with the standard setup just re adjusting?
Paul
