tallpaul1977
Nugget 1.8T
Hi everyone, after a few years off from owning a Corrado, I decided to buy this '91 1.8T that I found on Pistonheads. The interior wasn't in great shape and the Bilstein coilovers had seen better days. The engine conversion was carried out by Voodoo Motorsport and is running DTA standalone ecu and K04 turbo.
39759264845_2fd311763f_c.jpgIMG_20120930_135845 by Paul Taylor, on Flickr
40654567671_8175cc53a0_c.jpgIMG_20120930_135824 by Paul Taylor, on Flickr
40654567101_54a525ee58_c.jpgIMG_20120930_135907 by Paul Taylor, on Flickr
Edited by tallpaul1977
Stripped the car and bought a late spec interior from a friend, who turned out to have my Corrado about 10 years ago.
38845726680_30e37164a5.jpgFB_IMG_1474550781245 by Paul Taylor, on Flickr
Didn't really like the rear lights, so went for a set of full reds.
25783432347_b3d3fab84b_c.jpgIMG_20130203_161056 by Paul Taylor, on Flickr
Had a subframe and cross member lying around from a previous Corrado and had it shot blasted and painted black. New ball joints, wishbones, discs etc installed. The car came with Audi S2 front calipers and I fitted a set of HEL braided brake lines.
25783431847_a3ebd5efdb_c.jpgIMG_20130228_213951 by Paul Taylor, on Flickr
Full Vibratechnics engine mounts, wishbones and rear trailing arm bushes used, along with Powerflex for the cross member.
40653813101_72c7e56fd8_c.jpgIMG_20130123_211454 by Paul Taylor, on Flickr
Heat wrapped the K04 downpipe and bought a few Forge goodies - DV008, turbo inlet pipe, EGR blankig cover and carbon engine cover. Also installed Lupo front wipers.
39946430634_b28d75c824_c.jpgIMG_20120916_133331 by Paul Taylor, on Flickr
26783511998_ae6426e165_c.jpgIMG_20150301_155124 by Paul Taylor, on Flickr
To help the suspension, bought Wiechers carbon fibre front & rear strut braces, along with the front lower brace.
40614265092_89da66d270_c.jpgIMG_20120904_081635 by Paul Taylor, on Flickr
39946435954_bf4b314667_c.jpgIMG_20120904_081704 by Paul Taylor, on Flickr
40614265602_c779be66df_c.jpgIMG_20120916_155425 by Paul Taylor, on Flickr
The Bilstein coilovers had seized solid and couldn't adjust the height, so a set of KW Automotive Clubsports coilovers with adjustable top mounts were installed.
39759262985_2c1a7f0c6a_c.jpgIMG_20140807_165338 by Paul Taylor, on Flickr
8x17" Calibre Vintage with 205/40/17 Kumho V70 track tyres to finish it off. ET30 front and ET25 rear.
I do car detailing when I can and gave the Corrado a 3 stage machine polish, topped off with Auto Finesse Illusion wax
40612907692_e1aac56f4a_c.jpgIMG-20141116-WA0003 by Paul Taylor, on Flickr
40654568971_9815871a6e_c.jpgIMG_1710 by Paul Taylor, on Flickr
25784108677_2977168577_c.jpgIMG_0739 by Paul Taylor, on Flickr
After doing a few track days at Silverstone and Bedford Autodrome, I managed to strip 3rd gear of some of its teeth
39759243515_1aa076ecf0_c.jpgIMG-20141215-WA0003 by Paul Taylor, on Flickr
40612907452_f8d867abb4_c.jpgIMG-20141215-WA0004 by Paul Taylor, on Flickr
I can highly recommend Abbey Transmission Services in Nazing. The gearbox was fully rebuilt with new diesel gears, Peloquin limited slip diff and uprated clutch fork
39759243625_094d94ccb7_c.jpgIMG-20141215-WA0001 by Paul Taylor, on Flickr
40654563131_cecd77da6e_c.jpgIMG_20141217_133946 by Paul Taylor, on Flickr
38844512330_c90b01bd5f_c.jpgIMG_20141217_133934 by Paul Taylor, on Flickr
38844512680_ef8b906745_c.jpgIMG_20141201_092047 by Paul Taylor, on Flickr
40654564011_8c773d3c46_c.jpgIMG_20141201_092036 by Paul Taylor, on Flickr
Also fitted a Epytec clutch release lever before the gearbox went in
39759258535_fbd60d82f1_c.jpgIMG_20150115_192812 by Paul Taylor, on Flickr
26783513498_3dcc1d875c_c.jpgIMG_20150115_192921 by Paul Taylor, on Flickr
Wanted to make the most of the new refurb gearbox, so bought a GEMA short shifter and will be installing the Gruven short shift for reduced side to side.
40654579881_368f25e957.jpgarz_short_shifter by Paul Taylor, on Flickr
My rear number plate holder was broken, so the Corrado got treated to a carbon one from LWS Design
40612110532_43da9b837a_c.jpgcorrado_carbon_number_plate by Paul Taylor, on Flickr
A friend didn't like a set of BBS he bought, promptly snapped up for the Corrado. 8.5x16" 3 Piece with magnesium barrels.
ET30 front & ET25 rear with 215/40/16 Kumho KU31 tyres
25783422477_6117e1b19a_c.jpgIMG_20150227_220044 by Paul Taylor, on Flickr
40612109812_f2bfe11f95_c.jpgIMG_20150227_214842 by Paul Taylor, on Flickr
40654574831_f5f5c3a039_c.jpgimage by Paul Taylor, on Flickr
40654575181_b600b171c0_c.jpgimage(2) by Paul Taylor, on Flickr
39759269875_7e2f9e9a63_c.jpgimage(1) by Paul Taylor, on Flickr
Next job on the weekend is to see how low I can go :)
On the way to the ferry for DMPD 2015, I managed to get put a rather large hole in my Forge sump by catching a speed bump.
26783530448_61c1df6c59_c.jpgcorrado_broken by Paul Taylor, on Flickr
Thankfully one of the guys at Auto Finesse had a sump on one of his cars at home and with minutes to spare we made he ferry.
39944323634_530af6aaae_c.jpgScreenshot_2015-09-23-18-59-04 by Paul Taylor, on Flickr
40612906642_7d37042309_c.jpgIMG-20150914-WA0000 by Paul Taylor, on Flickr
40612913392_23ca7f6022_c.jpgIMG_20150912_180040 by Paul Taylor, on Flickr
39759242695_a952d4f78f_c.jpgIMG-20150914-WA0002 by Paul Taylor, on Flickr
40612914222_e044f96b2f_c.jpgIMG_20150912_135941 by Paul Taylor, on Flickr
Thanks for the comments guys, she's a labour of love!
rado20vT what intercooler do you use on your 1.8T?
I was running it with a renault traffic cooler but that was very wide so I will be changing to a smaller one, something like this
https://www.ebay.co.uk/itm/FMIC-Front-Mount-Alloy-Intercooler-420-x-160-x-65mm-Core-Universal-2-5-In-Out/332477934391?_trkparms=pageci%3Af16bb16f-23cb-11e8-9b2e-74dbd1809950%7Cparentrq%3A0c21888a1620a8664416cbb5fffd66e2%7Ciid%3A1&_trksid=p2481888.c100675.m4236
Busy time working on the car recently. Unfortunately I had a issue driving 1 day, when the front near side wheel felt like it was going to fall off. A few mechanics told me the gearbox was causing the issue, which was worrying after not long having the gearbox rebuilt. After refurbishing my dirveshafts and fitting new inner and outer cv joints and doing both front wheel bearings, the issue has gone.
While the car was on axle stands in my garage, I decided to tackle a few jobs
First up, rusty fuel tank straps.
40837785775_8095d4fa35_c.jpgIMG_20180210_112540 by Paul Taylor, on Flickr
Looking a lot better after being shot blasted and then treated with a zinc coating to help stop rust.
41019350514_58085ee237_c.jpgIMG_20180303_125957 by Paul Taylor, on Flickr
40837788315_2ff4cf7e01_c.jpgIMG_20180303_130053 by Paul Taylor, on Flickr
Sprayed black with chassis spray
41019345804_0a8f1ee8ee_c.jpgIMG_20180310_110213 by Paul Taylor, on Flickr
While getting the fuel tank straps done, I had my rear caliper carries shot blasted and coated, ready for the MK4 Golf rear calipers
40837787735_5cbe1be907_c.jpgIMG_20180303_130139 by Paul Taylor, on Flickr
Gloss red to match the Porsche Brembo calipers
40837786745_0931b8484f_c.jpgIMG_20180310_110000 by Paul Taylor, on Flickr
41019344124_f15759b44b_c.jpgIMG_20180422_101259 by Paul Taylor, on Flickr
41019342854_8fcde41826_c.jpgIMG_20180422_131649 by Paul Taylor, on Flickr
Brembos are a tight squeeze under the 16" BBS
41229121985_cb12773b48_c.jpgIMG_20180422_151822 by Paul Taylor, on Flickr
