Roger Chatfield 0 Posted December 10, 2015 Morning chums, I'm going to remove my abs unit in the next couple of days in an attempt to fix it. Now, when I replace it what's the correct procedure to bleed it? Is it just a case of undoing the bleed nipple on the top or is there something else I need to do? Rog. Quote Share this post Link to post Share on other sites
Harrier 1 Posted December 10, 2015 You would need to bleed it at the abs pump and still probably at the calipers Rog, Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 10, 2015 Yeah I'd suggest a complete change and bleed at every part, including clutch Rog. These cars seem to exagerate every tiny trapped air bubble with a horrific pedal feel and dangerous braking if you so much as change a bleed nipple cover, so worth going to town on it mate. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 10, 2015 Not sure if its the same on the original corrado ABS, but when i swapped to the newer system i had to bled the pump using vagcom Quote Share this post Link to post Share on other sites
Tjninny 10 Posted December 10, 2015 Noticed that Ed conveniently "forgot" to show how to refer abs pump on Wheeler Dealers Corrado. Quote Share this post Link to post Share on other sites
Tjninny 10 Posted December 10, 2015 Bloody predictive text!!! Meant to say refit not refer!! Quote Share this post Link to post Share on other sites
Harrier 1 Posted December 10, 2015 Will be bleeding my recently fitted replacement unit very soon, will let you know how I get on. Quote Share this post Link to post Share on other sites
ChrisL 18 Posted December 13, 2015 Just bleed the whole system using something like an easibleed. Start at the caliber furthest away from the master cylinder and work towards it. The abs is bled with the 2 nipples on the top. Don't forget the clutch and master cylinder last. No need for VAGCOM when bleeding. Can be a pig of a job I've found. Quote Share this post Link to post Share on other sites
Harrier 1 Posted December 13, 2015 (edited) Had a go at bleeding mine conventionally this morning and got a reasonable pedal without much trouble.Can't do the rears though until it's out of the garage. There is a 7mm bleed screw on the end of the master cylinder too, start there-abs-then calipers. Edited December 13, 2015 by Harrier Quote Share this post Link to post Share on other sites
