seanrodford
Vr6 clutch master cylinder
http://www.ebay.co.uk/itm/Clutch-Master-Cylinder-VW-CORRADO-53I-2-9-VR6-Coupe-190-BHP-Top-German-Quality-/400777974942?hash=item5d503a949e:g:cFAAAOSwQItUIal3
I bought one like this. Same pipe layout and connection to the pedal etc. Just have to remove the 8mm studs on the corrado (10 min job) that holds your original on and use 6mm bolts with locking nuts.
Changed the slave at the same time. Now a perfect feeling clutch with a bite point a lot higher than the old tired set up gave me.
