tonylam 10 Posted July 16, 2016 Hi All. I am a new owner of a 1993 VR6 Corrado. Its a bit of a find and has not run for 4 years. it did 26 miles after being last serviced then was put to bed. The oil is like it just can from the can. there have been no fluid leaks over the years. I have drained the fuel out and replaced it. and fitted a nice new battery. The engine turns over easily but would not start. i have checked and confirm i am getting ignition. there is fuel flowing to the injectors. still nothing. i have sprayed fuel into the air intake and the vehicle runs. i have read that the crank sensor could be failing to provide a signal so have replaced this. I have checked the fuses and reseated the relays......still nothing. what am i overlooking? oh one thing i have noticed. when i switch the ignition on the water pump is running!!! not sure they are related but i thought id mention it. i have a snap on souls pro which connected the the 2x2 diagnostic which is showing the 0513 g28 no signal code but i read that is normal when they don't start?? any help appreciated. i want to get this cool car back on the road where she belongs Cheers Tony Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 16, 2016 Welcome to the forum - might be worth checking the plugs aren't oiled up... If it's a distributor model have you checked the rotor arm and cap? I'd try a new ECU relay and also consider get a new ignition switch if it's not got the newer (black 6NO) type fitted. Have you tried shaking the key when it the crank position? (sometimes starts if switch is faulty) Is there an aftermarket alarm fitted? maybe a fuse somewhere you can't see. The G28 error is normal for that engine as you say when not running so ignore that for now. Quote Share this post Link to post Share on other sites
Cressa 44 Posted July 16, 2016 Lucky you, the auxiliary water pump should be running as soon as the ignition is on, and sometimes will over run with the fans if the engine is above a certain temperature. Good luck with starting it Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 17, 2016 Thanks for the comments. Supercharged its not a distributor model but I will replace the ECU Relay, thanks. Cressa thanks for the info on the auxiliary water pump. I was beginning to think is had short on that circuit My gut is telling me it may be the Cobra Thatcham alarm. It seems to be operating but it has an immobiliser module which cuts into the fuel injection system. I am stripping it back to remove this connection with a hope that will get the injectors firing. I will post the end result on here Cheers Tony Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 18, 2016 No nothing happening. stripped the immobiliser module out and same as before. I am guessing now that it could be a fault on the ECU. The car had the scuttle trays removed so is most likely has gotten wet. there does not appear to be any issues with water ingress but you never know. Does anyone have a 021 906 258 AG eco lying about or can anyone recommend an ECU tester/repair/refurbish company with a good reputation. I am in the NW of England but would post if required. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 18, 2016 Have you tried the ECU relay or ignition switch yet? Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 18, 2016 When you say you have ignition , your saying you have a spark at the plugs ? . Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 18, 2016 Hi supercharged. The relay appears to be working. relay 109 whilst having 4 pins is only a 3 pin relay. Pin 85 is ground and pin 30 is the mag circuit positive. when the circuit is energised the current from 30 runs across to pin 87. The ignition also appears to be functioning. all electrical ignition on stuff is powered up on the key, windows, radio, light, sunroof, horn etc I did try the key wiggle Robrado. Yes by ignition i mean the plugs do spark. when i spray petrol into the air intake the engine runs. it seems to be the fuel injectors are not firing. still open to suggestions or if anyone have an eco i could try or indeed buy. Tony Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 19, 2016 Has anyone heard of the ECU Doctor in Plymouth. Anyone had experience of them? Can anyone point me at a local firm in Lancashire? Tony Quote Share this post Link to post Share on other sites
Dox 23 Posted July 19, 2016 http://camcoautomotive.co.uk/workshop.html Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 19, 2016 (edited) If you can talk to the ECU and get an error code back there is not likely to be anything wrong with it. It's not like it's a Pentium or anything. Check all the engine sensors that feed into the ECU for continuity and signal. Just my opinion. The Motronic ECU uses crank, cam, inlet temp, lambda, MAF and coolant temp (all I can remember for now) to make its decisions. Might also be worth getting your fuel pressure tested and checking for any air leaks. Oh and there's a throttle position sensor too. Edited July 19, 2016 by fendervg Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 20, 2016 Hi guys. Can i ask, how does the fuel get to the rail and how is it pressurised? when i switch on the ignition i cannot hear an electric fuel pump running. when i release the fuel rail relief screw, no fuel flows out. however, when i try and start the engine fuel squirts out. Is the fuel pumped electrically or mechanically?? Tony Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 20, 2016 Its electrically from an in-tank fuel pump. First things first though, pop off your fuse box cover and check the fuel pump relay (above the fuses). You should hear/feel it "ping" as it energises. This makes the circuit to the pump, and you should hear a light hum as the pump primes. The relay is a common failure item, so worth checking if you're getting no fuel. It should be numbered 67, or 167 depending on date of manufacture. Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 20, 2016 Seanl82. Thanks for the info. I will check it out tomorrow. Tony Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 20, 2016 Electric pump under the boot floor in the petrol tank. It should run at 4 bar. Test your fuel pressure at the rail and check your fuel pressure regulator on the right hand side of the rail. You might have a problem with residual pressure due to a leak somewhere. You won't hear a good pump prong or running, but the relay should energise as above. Most of the info is there. Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 22, 2016 Quick update and another question. Fuel pressure is 4.2 bar. The fuel pump is quite quiet but appears to be working well. Relays are working. i find myself focussed on the firing of the injectors again. I have taken the plenum chamber off and removed a couple of the injector connectors. i am measuring 12volts across the terminals as soon as the ignition comes on. Is this right. i had expected the voltage to be zero and pulse as the injector fired. any advice? Thanks Tony Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 22, 2016 Are your injectors leaking or have worn seals? Not sure about the voltage, but maybe your engine is flooding. You should also have about 3 to 3.5 bar residual pressure at the rail after an hour so of the engine off. It could be a dodgy ECU but maybe the injectors open when there is no voltage? I'm not sure. Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 22, 2016 found this on another forum The injector pulse is a ground and not + voltage. The injector harness should have a +12 constant voltage. If I recall correctly, the ECU ground which pulses has resistance to a chassis ground and you may get 4.8 volts by not checking to an ecu ground instead of abattery ground.. been so long since I worked at audi that I don't remember all of the elsa specs on checking the computer. Do check the cam speed sensor and make sure it too is getting its signal to the ECU. also the residual pressure is dropping rather quickly. drops to zero after approx 5 mins. no obvious leaks. do the residual pressure regulators breakdown?? leak fuel back Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 23, 2016 You should fit a non return valve on the feed hose just above the pump in the boot. If you search my old threads for fuel pump and pressure on here there's loads of info and links. Btdt Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 23, 2016 Or you might have a leaking hose or feed line or a faulty FPR. Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 23, 2016 FPR, is around 80.00 if I remember correctly . Quote Share this post Link to post Share on other sites
fendervg 32 Posted July 23, 2016 Should be able to get the Bosch one for about half that. Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 23, 2016 My one was from Tps or VW. Quote Share this post Link to post Share on other sites
tonylam 10 Posted July 24, 2016 Hi everyone. i will be putting a non return valve os the fuel line, thanks for the tip. The good news is she lives. I replaced the ECU. i had been turning the motor over on the key for the past week whilst trying various options so i could see oil at the head. I connected the replacement ECU and with fingers crossed turned the key. she started on the key with me outside of the car. Fabulous She was a bit tappetty at first. Well 5 years of nothing will do that. I let her idle till the motor warmed up and the oil found its way to the hydraulic followers but she has settled down well and is purring. Well pleased as soon as i work out why i cannot post some images ill get some uploaded thanks for the input. tony Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 24, 2016 Good stuff ! . Quote Share this post Link to post Share on other sites
