edd 0 Posted June 5, 2017 Hi All, Just putting in an order to VW Heritage, does anyone know if the Mk2 to Mk4 Goodridge hose kit is okay, they are advised online as being 230mm in length. https://www.vwheritage.com/wc69805062p-goodridge-stainless-brake-hoses-mk2-golf-to-mk4-rear-calipe i have asked the VW Heritage team who have advised they can get custom ones made up for same price if not compatible, but no need if these are sufficient Anyone used them? Edd Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 5, 2017 These are the correct ones, although you don't need conversion hoses for the rear - just the fronts as the fittings are exactly the same. Quote Share this post Link to post Share on other sites
edd 0 Posted June 5, 2017 sorry Sean, excuse my tired brain, what exactly do you mean by that when you say I don't need conversion hoses, is this for the end without the banjo type connector? Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 6, 2017 Yeah fronts need a banjo fitting if converting to mk3 or mk4 calipers, but the rears are direct replacements and new hoses aren't really needed as the fitting is the same as standard corrado calipers Quote Share this post Link to post Share on other sites
Dox 23 Posted June 6, 2017 Yeah fronts need a banjo fitting if converting to mk3 or mk4 calipers, but the rears are direct replacements and new hoses aren't really needed as the fitting is the same as standard corrado calipers Rear MK4s are banjo fitting? Quote Share this post Link to post Share on other sites
edd 0 Posted June 6, 2017 Yeah i am getting more confused, I thought mk4 rears were banjo type and that's why you need replacement hoses? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 23 Posted June 6, 2017 Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted June 6, 2017 Info on this page for parts http://the-corrado.net/showthread.php?40893-Mk4-Golf-Rear-Calipers-Upgrade.-Re-Parts&highlight=mk4+rear+brakes Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 6, 2017 Apologies, seems I'm getting a bit confused in my old age. I remembered the fronts having a screw fitting but not the rear. :scratch: As you were!....... Quote Share this post Link to post Share on other sites
Dox 23 Posted June 6, 2017 Apologies, seems I'm getting a bit confused in my old age. I remembered the fronts having a screw fitting but not the rear. :scratch: As you were!....... Easily done Sean, I've purchased parts that in my mind fit, but are very wrong in practice. Quote Share this post Link to post Share on other sites
