Marin
What (which) V8 and V10 Engine can swap (fit) into Corrado?
Hello everybody!
Do any one knows what (which) V8 and V10 Engine (VW, AUDI and any other Brands/Marks) can swap (fit)(correctly) into Corrado without touch (make deep/high up) the hood?
And do any one knows for some site as engine data, something as Auto Data (Car Data), where can watch and see about any kind of car engines and their specs: weight, height, width, (also in 3D), etc.
Thank you all!
serious!
Also willing to made Corrado (AWD/4WD/4x4) quattro (from VW Passat B5 and B5.5 4Motion with "Torsen" and from Audi A4/S4/RS4 - "Torsen") and maybe Syncro or not and not 4Motion - not "Haldex"...
Guys, did you watch that VW Golf MkIV R32 – Twin Turbo V10 Swap (about 1.200 HP)!
It would be a serious amount of fab work to 'drop' the running gear from a V8 audi into a corrado.
If you are anywhere near to Reading you're welcome to come over with a tape measure; I have a V8 S4 and G60.
If you have the skills to do this sort of thing you wouldn't be asking here for here for advice.
Big v8,pro built by Chris Issac race cars
He used to come on here when the car was being built
Spencer Tramm was his name,engine is a Chevy 468cuin big block
Edited by dragon green
Thank you marks2, but am far from you... interesting about S4 (B6), S4 and RS4 (B7) 4.2 V8 "naturally aspirated engines", then to add (fit) Bi-Turbo (Twin Turbo) or Big Turbo or Supercharger... and whole (mechanic) quattro (4WD differential) system... to buy an damaged (wrecked) car and engine (with transmission) and quattro, brakes, etc. as donor car...
Edited by Marin
