spen 0 Posted June 22, 2017 One side not working tried a quick glue repair to no avail, looking for a replacement from the tee piece or anything close Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted June 22, 2017 Can you not measure what size tube it is and get some from halfords? Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
spen 0 Posted June 22, 2017 Can't remove from fitting because I glued it! need from the tee piece Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted June 22, 2017 slice a slot in it along the length and peel back. If necessary, spray some wd40 to attack the glue. Should enable you to remove it. Quote Share this post Link to post Share on other sites
spen 0 Posted June 22, 2017 just hope the end part which fixes through the bonnet hasn't got glue in it🤞🏻 Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted June 22, 2017 you can take it apart - i posted a stripdown of my spray jet: http://the-corrado.net/showthread.php?74917-heated-washer-jet-wire-repair-with-pics Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 22, 2017 Replaced all mine, am sure its pretty similar dia to aquarium airline. Might have been what i used. Quote Share this post Link to post Share on other sites
spen 0 Posted June 22, 2017 Nice one fla cheers Jim Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 22, 2017 Yep, I got mine and replaced the lot with the same inner and outer diameter (cant remember the dimensions now) from Halfords. Less than £2 with a trade card, not a lot more without one! Quote Share this post Link to post Share on other sites
spen 0 Posted June 22, 2017 Cheers Sean Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
