Will.I.Dub
VR6 timing chain kit questions
Did you ask the dealer? Don't think VW parts cost much more and I have heard that the gaskets in particular are better quality.
A Corrado is for life, not just for the MOT.
I bought the revised timing chain kit from Stealth, Vince had it in stock and on the shelf - gaskets I bought ether from Heritage or Main Stealer, all have been listed/sold as genuine VW and all have been Elring.
Good advice, for some reason I thought that nearly all parts were obsolete from VW but below are prices they came back with today, I am unsure if these are the newer style parts or not. List is from the Wiki here. Can anyone confirm?
(In €uro, without discount & VAT @ 23%)
1 021109465B timing chain (lower) - €69.51+vat + available in the UK
2 021109467 chain tensioner (lower) - €39.95+vat + available in the UK
3 N90535001 M6x24 allen bolt (lower tensioner) - €0.40c +vat each X 2 + available in the UK
4 021109469 side rail (lower) - €7.93+vat + available in the UK
5 021109471 side rail pin (lower) - €3.62+vat + available in the UK
8 N10203803 M12x1.5x40 (mid pulley) - €3.09+vat + available in the UK
9 021109503A timing chain (upper) – Dropped on the 01/03/14 without replacement
10 021109511 chain guide pin (upper) - €18.72+vat + available in the UK
11 021109507A chain tensioner (upper) - €75.26+vat + available in the UK
12 N0138271 chain tensioner seal (upper) - €1.02+vat + available in the UK
13 021109509A chain guide (upper) - €39.95+vat + one showing available in the UK
14 021109515A side rail pin (upper) - Dropped on the 01/07/2016 without replacement
15 021109513 side rail (upper) - €18.23+vat + available in the UK
16 *N01152520 washer - €0.31+vat + available in the UK
17 N0102724 M8x26 hex bolt - €0.54+vat + available in the UK
18 *N01152520 washer - €0.31+vat + available in the UK
19 N01035210 M8x55 hex bolt - €1.08+vat + available in the UK
Edited by Will.I.Dub
Thanks Geeba, I'll give them a shout
Good advise,for some reason I thought that nearly all parts were obsolete from VW but here is the list & prices they came back with today:
Odd... When I called the dealer I was told pretty much every part was obsolete from about 2014.
Make sure you get the revised tensioner without the rivits.. I found bits of mine in the oil pump strainer.
Sent from my ONEPLUS A3003 using Tapatalk
If you want the revised tensioner you have to give them the right part number. They won't look it out for you.
Thanks Matt, would you know that part number by any chance?
Sounds good - at least you know you will be getting all the right parts. Let us know how you get on. Are you doing the clutch as well?
The kit has arrived from Vince, he took out all the guess work.
I am doing the clutch as well, it probably needs the clutch more than the chains but I hear a strange little rattle under load which could be chain/tensioner related and I'd like to rule it out.
I would be wary, seems very cheap
I fitted a Febi Bilstein kit to mine, cost around £200
No way I would be putting an 80 quid Chinese timing chain on a VR6 engine... if it fails it's the end of the engine.
How much does Vince charge for all the bits for the timing chain job?
Does he supply a full kit for a head gasket and clutch change?
Im just beginning to think longer term and stashing bits away to make sure i don't get caught short in the future.
I only bought the chain kit from him, and a cheeky BMC intake. TBH without rooting out the invoice I can't remember exactly how much as I bought so many parts from all over at the same time. If I come across it I'll let you know
