Coops 0 Posted January 22, 2018 Hi, Looking for part number 535 919 235 BA, for 1995 VR6 Thanks Coops Quote Share this post Link to post Share on other sites
gotvach 10 Posted February 10, 2018 Not sure what the rules are on posting links to auction sites but happened to come across an abs light on ebay, item 282843070527 (not my auction). Quote Share this post Link to post Share on other sites
Dox 23 Posted February 10, 2018 Not sure what the rules are on posting links to auction sites but happened to come across an abs light on ebay, item 282843070527 (not my auction). Its been done loads of times to help out others. https://www.ebay.co.uk/itm/Vw-Corrado-Vr6-Abs-Warning-Light-Part-Number-535919235ba/282843070527?hash=item41dac2c03f:g:hRMAAOSwlpZaftto Quote Share this post Link to post Share on other sites
Dox 23 Posted February 17, 2018 Jesus Christ what a price! Quote Share this post Link to post Share on other sites
fendervg 32 Posted February 17, 2018 That's a joke. What's broken on the one you have? It's a really simple circuit board and you can easily solder in a replacement bulb or even better, an LED with resistor. Quote Share this post Link to post Share on other sites
Coops 0 Posted March 28, 2018 That's a joke. What's broken on the one you have? It's a really simple circuit board and you can easily solder in a replacement bulb or even better, an LED with resistor. I have soldered a new bulb in, but it just flashes for a second when you turn the car off. I have put my mates abs light in and it works perfectly so nothing wrong with the car. Will have to solder 3 new resistors in and see if that works. Thanks for the replies. Quote Share this post Link to post Share on other sites
marks2 0 Posted March 29, 2018 (edited) As stated in my previous post there are 2 diodes and a resistor alongside the blub. I doubt these have failed. What blub did you use? Was it a 12v 0.96W? I'd not be surprised if the ECU measures the current to check the blub is working. Edited March 29, 2018 by marks2 Quote Share this post Link to post Share on other sites
fendervg 32 Posted March 29, 2018 It does. It checks the return voltage, and if not present disables ABS. This is to allow for faulty wiring in the loom, broken PCB or blown bulb. Quote Share this post Link to post Share on other sites
marks2 0 Posted March 29, 2018 (edited) Just a note re. the LED replacement then; you'll need to ensure the current draw equates to the same as the filament bulb. Edited March 29, 2018 by marks2 Quote Share this post Link to post Share on other sites
Coops 0 Posted April 1, 2018 Just a note re. the LED replacement then; you'll need to ensure the current draw equates to the same as the filament bulb. Thanks for the info, I will check on the bulb👍 Quote Share this post Link to post Share on other sites
