George Lee 10 Posted January 30, 2018 Trying to figure out why my abs light is on. Tried scanning it before using this Got it all connected but for some reason it couldn't read the ecu. Anyone else has a problem scanning a 2.0 16v? Mine is 1992. And help is much appreciated Thanks Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted January 30, 2018 Most scanners will only read cars from 1996 on If you can get hold of a sanp on scanner it will read it Quote Share this post Link to post Share on other sites
George Lee 10 Posted January 30, 2018 Most scanners will only read cars from 1996 on If you can get hold of a sanp on scanner it will read it Oh right snap on ? I've done mk3 golf with this in the past Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Geeba 0 Posted January 30, 2018 The "about scanner" says it's OBD2... The Corrado will be OBD1. Quote Share this post Link to post Share on other sites
George Lee 10 Posted January 30, 2018 The "about scanner" says it's OBD2... The Corrado will be OBD1.Yeah I've read somewhere about that but then I've also seen people say that it will do both. So many different answers but that makes sense Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Philly-R6 0 Posted January 31, 2018 If you are near South Manchester, I can try and read the codes for you with VCDS ? Quote Share this post Link to post Share on other sites
George Lee 10 Posted January 31, 2018 Think I've found a reason why it could be on Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Dox 22 Posted January 31, 2018 Think I've found a reason why it could be on Sent from my SM-G950F using Tapatalk Give us a clue? Quote Share this post Link to post Share on other sites
George Lee 10 Posted January 31, 2018 Give us a clue?Possibly because of the state off them ? Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
Dox 22 Posted January 31, 2018 Possibly because of the state off them ? Sent from my SM-G950F using Tapatalk Them, being the reluctor rings having slight rust? They all look similar to that being mild steel and underneath a wheel arch. Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 31, 2018 Just saw your other post, I take it the car hasn't seen the road in a while? If I were you, get your brake disks and pads sorted, then go for a short drive. Once you're over 15mph the ABS system will become active so it'll either go off and all will be well, slam on the brakes a few times to see if the pump valves kick in and clear up if they've become a bit sticky, or get a multimeter and google the wheeler dealer episode on the Corrado to check your sensors, or have a search on this forum for the link to the guide I did on my old mk3 Golf (pretty much the same) to see if your sensors are working. Other than that, get a different OBD reader or ask around if there is someone close with VCDS who will read the codes for you. Not seen that OBD reader before so no idea why it won't connect. Probably compatibility of some sort. Quote Share this post Link to post Share on other sites
