1xshaunx1 27 Posted April 4, 2020 After all that, it looks like they used this calliper on the mk3 and mk4 with a 288 by 25 disc. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted April 4, 2020 16 minutes ago, 1xshaunx1 said: After all that, it looks like they used this calliper on the mk3 and mk4 with a 288 by 25 disc. Then if it's what it is and I think you're right about this, as per another comment on this tread, maybe upgrading to the mk4 refurbish kit would be a good idea to eliminate the problem of the pistons rusting out... Thanks for the link as well! Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 4, 2020 A list of cars that had them fitted https://www.yoyopart.com/oem/7366698/vag-3a0615123a.html Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted April 4, 2020 Fantastic! Thanks for your help on this, much appreciated mate! Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 4, 2020 I saw some nice brembo callipers with the same spec somewhere. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted April 4, 2020 1 minute ago, Keyo said: I saw some nice brembo callipers with the same spec somewhere. Oh really? That could be an interesting setup for sure! Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 4, 2020 (edited) https://www.autopartspro.co.uk/brembo-7779969 Hummm says not for ABS though. Must be correct though as matches part number. Edited April 4, 2020 by Keyo Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted April 4, 2020 40 minutes ago, 1xshaunx1 said: After all that, it looks like they used this calliper on the mk3 and mk4 with a 288 by 25 disc. Well done Shaun, I'd be 99% sure thats the right kit, in fact I'm ordering a set now for a planned refurb of my 288's Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 4, 2020 https://www.clubgti.com/forums/index.php?threads/mk4-288-calipers-same-as-mk3.245858/ Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted April 5, 2020 https://www.ebay.co.uk/itm/VW-Golf-MK4-1-8-GTi-Turbo-Front-Brake-Caliper-Piston-P54058GL/332416104279?epid=7015975312&hash=item4d658b3757:g:3XcAAOSwbWZaVQ3H All the measurements of the piston on there Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 5, 2020 I bet if you order the Brembo one an ATE one will come in a Brembo box Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 5, 2020 (edited) 6 hours ago, 1xshaunx1 said: I bet if you order the Brembo one an ATE one will come in a Brembo box Possibly mate I have never purchased a set so could nt vouch for them. Have any of you got the 312 disc fitted to Mk4 callipers with the 6mm spacer ? I imagine Shaun you will need some serious brakes with the power you are running. Whe I owned a Mustang S550 they had 6 pot and 4 pot Brembos but the car weighed 1720 KG with the 5.0 coyote lump in it. Edited April 5, 2020 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 5, 2020 Standard set up on mine but with Brembo grooved discs and the ferodo pads below. A lot more stopping power and less fade Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted April 5, 2020 I had 312 mms fitted on teves 2.0 system I went back down to 288's as I felt that there was no discernible difference in stopping power but the weight of the discs and 16'" inch wheels on low profile tyres ruined the handling feel. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted April 5, 2020 19 minutes ago, stuarttaylor37 said: I had 312 mms fitted on teves 2.0 system I went back down to 288's as I felt that there was no discernible difference in stopping power but the weight of the discs and 16'" inch wheels on low profile tyres ruined the handling feel. Thanks good to know, thanks for sharing your experience. I was starting to consider this option but now I'll keep it to Mk3 DE. Cheers! Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 5, 2020 1 hour ago, stuarttaylor37 said: I had 312 mms fitted on teves 2.0 system I went back down to 288's as I felt that there was no discernible difference in stopping power but the weight of the discs and 16'" inch wheels on low profile tyres ruined the handling feel. I've got a small one just 280 stock ha ! Did any factory Corrado VR6 come with 288 Im sure ive seen somewhere before some folks claiming there;s came from factory with 288. Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 5, 2020 5 hours ago, 1xshaunx1 said: Standard set up on mine but with Brembo grooved discs and the ferodo pads below. A lot more stopping power and less fade Very nice. Quote Share this post Link to post Share on other sites
tonedef 10 Posted April 5, 2020 23 minutes ago, Keyo said: I've got a small one just 280 stock ha ! Did any factory Corrado VR6 come with 288 Im sure ive seen somewhere before some folks claiming there;s came from factory with 288. None came out of the factory with 288s as far as I’m aware. They only just squeeze inside the standard Speedlines, you have to be careful where the balance weights go or they get jammed between the rim and calliper, wouldn’t be good for a standard set up! Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted April 5, 2020 42 minutes ago, Keyo said: I've got a small one just 280 stock ha ! Did any factory Corrado VR6 come with 288 Im sure ive seen somewhere before some folks claiming there;s came from factory with 288. I've seen one person claiming that but if its true (which I doubt) there can"t be many Quote Share this post Link to post Share on other sites
Dox 31 Posted April 5, 2020 Facebook edition? Quote Share this post Link to post Share on other sites
Keyo 49 Posted April 5, 2020 I 6 minutes ago, Dox said: Facebook edition? Ha probably Dox- no dealt somebody purchased a car second hand that the last owner had upgraded to 288 as there is no 288 on the diagrams just checked. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted April 5, 2020 20 minutes ago, Dox said: Facebook edition? Yep Absolutely swore blind that they were original fitment Quote Share this post Link to post Share on other sites
