Cressa 44 Posted July 13, 2020 (edited) Cant believe I wrote that title 😂 anyway, On the scuttle trim area there is a small hole next to the wiper that is not for the trim clips, so what goes in here? See picture..... if nothing I will put silicone to blank it off. Any answers welcome to this one !! Edited July 13, 2020 by Cressa Forgot the picture Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 21, 2020 (edited) 30 minutes ago, Cressa said: Bump.... Mate looks like another hole to take one of them white clips ? How many do you have in place ? Edited July 21, 2020 by Keyo Quote Share this post Link to post Share on other sites
Cressa 44 Posted July 21, 2020 I have 10 in position and they line up correctly with the trim that will fit onto them. . This seems spare.. maybe I should triple check it!! Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 21, 2020 36 minutes ago, Cressa said: I have 10 in position and they line up correctly with the trim that will fit onto them. . This seems spare.. maybe I should triple check it!! Did you put the plastic sleeve grommets in the holes first mate . Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 21, 2020 Has anyone ever seen this seal before Im not familiar with it . No 7 on diagram. https://volkswagen.7zap.com/en/rdw/corrado/cor/1994-76/8/853-158000/#7 Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 21, 2020 Cressa do you know your corner tailgate bump stops - where they land when shutting the boot there are two dimples in the bodywork a bit like the spoiler- you are meant to have two circular clear protection decals on there mate to protect the paint. Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 21, 2020 31 minutes ago, Keyo said: Has anyone ever seen this seal before Im not familiar with it . No 7 on diagram. https://volkswagen.7zap.com/en/rdw/corrado/cor/1994-76/8/853-158000/#7 Says for vehicles with A/C Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 21, 2020 (edited) 31 minutes ago, Keyo said: Has anyone ever seen this seal before Im not familiar with it . No 7 on diagram. https://volkswagen.7zap.com/en/rdw/corrado/cor/1994-76/8/853-158000/#7 No I've never seen that seal in the flesh, says it's for Corrado's with air con, possibly for LHD options only ? It's listed at Classic Parts on their website. Si Edited July 21, 2020 by vw rule Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 21, 2020 (edited) Sure but also has two other options with cut to this length - I have not got one on mine was just wondering if I had it missing- I have seen in the past on diagrams as well they have special seals for for countries with dust - for example the one seal we don't see much the one under the door which are obsolete by the way and were hugely expensive- dust version ones are available though . Edited July 21, 2020 by Keyo Quote Share this post Link to post Share on other sites
Dox 22 Posted July 21, 2020 It’s a piece of hard clear plastic, I imagine it’s a spacer to prevent the screen sinking too deep into the adhesive?Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 21, 2020 41 minutes ago, Keyo said: Sure but also has two other options with cut to this length - I have not got one on mine was just wondering if I had it missing- I have seen in the past on diagrams as well they have special seals for for countries with dust - for example the one seal we don't see much the one under the door which are obsolete by the way and were hugely expensive- dust version ones are available though . Not 100% sure but think that seal in question possibly fit's behind grill, close to top of air con rad, might even help to seal under front edge of the top plastic fan guard. Plus as the 4 cyl & 6 cyl engine's have different sized / shaped top fan guards, hence the possible need to cut the seal down a bit to fit ? According to Classic Parts the standard uncut seal measurements are: Length 481mm / width 29mm / hight 9mm Yeah I know the bottom door seal you mean, I bought one when they were still available back in 2006, they normally only last 8 to 10 years if you're lucky, the plastic clips would break up or the seal would split / tear. They cost something like £65 to £70 back then per side. Si Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 21, 2020 1 hour ago, Dox said: It’s a piece of hard clear plastic, I imagine it’s a spacer to prevent the screen sinking too deep into the adhesive? Sent from my iPhone using Tapatalk That looks like the grommet chap that houses the white clips - I imagine they also stop the clip damaging the paint when you click the clips in - can still get them from heritage . Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 22, 2020 6 hours ago, vw rule said: Not 100% sure but think that seal in question possibly fit's behind grill, close to top of air con rad, might even help to seal under front edge of the top plastic fan guard. Plus as the 4 cyl & 6 cyl engine's have different sized / shaped top fan guards, hence the possible need to cut the seal down a bit to fit ? According to Classic Parts the standard uncut seal measurements are: Length 481mm / width 29mm / hight 9mm Yeah I know the bottom door seal you mean, I bought one when they were still available back in 2006, they normally only last 8 to 10 years if you're lucky, the plastic clips would break up or the seal would split / tear. They cost something like £65 to £70 back then per side. Si Really!? Mine are still there in excellent shape, and were removed/refitted with new clips when I had the respray. Quote Share this post Link to post Share on other sites
Cressa 44 Posted July 22, 2020 8 hours ago, Keyo said: Cressa do you know your corner tailgate bump stops - where they land when shutting the boot there are two dimples in the bodywork a bit like the spoiler- you are meant to have two circular clear protection decals on there mate to protect the paint. Yes mate, mine were actually black . I stamped some out the material you recommended b4 And yes, my grommets have been put in prior to the clips Quote Share this post Link to post Share on other sites
Cressa 44 Posted July 22, 2020 7 hours ago, Keyo said: That looks like the grommet chap that houses the white clips - I imagine they also stop the clip damaging the paint when you click the clips in - can still get them from heritage . Maybe I should just put a grommet in... nothing else listed in etka. Mine did have a blob of black sealant covering it, which i assumed a previous windscreen fitter had done to hold the trim Quote Share this post Link to post Share on other sites
blue95 0 Posted July 22, 2020 MIne just has one of those white clips over it Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 22, 2020 5 hours ago, seanl82 said: Really!? Mine are still there in excellent shape, and were removed/refitted with new clips when I had the respray. Blimey that's not bad going if you've still got yours in good nick, mine started splitting hanging down slightly a year or so after I bought my car in early 2002, and my old school mate bought his 1990 G60 about 18 months before I got my 16v, and his lower door seals were similar to mine. I never really gave that area much interest it was only when I saw something sticking out when the door was shut, the only thing I can think of is if my door hinges are warn, and the door/s have dropped slightly causing the seal to drag more on the door step sill ? Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 22, 2020 5 hours ago, Cressa said: Maybe I should just put a grommet in... nothing else listed in etka. Mine did have a blob of black sealant covering it, which i assumed a previous windscreen fitter had done to hold the trim Like Keyo has said I would double check to see how all the hole's line up with the ones in the scuttle trim, and if found to be surplus to requirements, I'd just put in that hole a thin small flat rubber bung, job done 👍 Si Quote Share this post Link to post Share on other sites
Dox 22 Posted July 22, 2020 It’s one of those clips with claws on the back that open up when you insert a dowel in the middle. It held nothing in my carSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 22, 2020 (edited) Just a thought here but dont LHD have different windscreen lower trims and might house different hence another hole that would be used on LHD versions ? I know they have different wiper links so different construction for sure. Edited July 22, 2020 by Keyo Quote Share this post Link to post Share on other sites
Keyo 47 Posted July 22, 2020 1 hour ago, Dox said: It’s one of those clips with claws on the back that open up when you insert a dowel in the middle. It held nothing in my car Sent from my iPhone using Tapatalk That looks like a Mk2 seat rail trim clip at the hole on the back of the trim to house it to the rail . Quote Share this post Link to post Share on other sites
Cressa 44 Posted July 22, 2020 6 hours ago, Keyo said: Just a thought here but dont LHD have different windscreen lower trims and might house different hence another hole that would be used on LHD versions ? I know they have different wiper links so different construction for sure. I'm leaning to this way of thinking, as the 10 clips line up with the trim lugs Quote Share this post Link to post Share on other sites
Cressa 44 Posted July 22, 2020 8 hours ago, Dox said: It’s one of those clips with claws on the back that open up when you insert a dowel in the middle. It held nothing in my car Sent from my iPhone using Tapatalk 👍 Quote Share this post Link to post Share on other sites
Dox 22 Posted July 22, 2020 56 minutes ago, Cressa said: I'm leaning to this way of thinking, as the 10 clips line up with the trim lugs If it was for LHD wipers it would have a redundant hole on the passenger side for the spindle? Like MK2 Golf. I think the holes are for a jig to help weld in the scuttle panel true? Quote Share this post Link to post Share on other sites
