_Matt_ 33 Posted July 13, 2022 I should know this but not attempted the mounts on the VR6. I'd like to refurbish my wishbones before getting an alignment after doing some works in the area. I can see I need to jack up the engine to allow room for the front wishbone bolt to come out - I had a quick look at the mount and it seems there is bolt on the top securing a heatshield - does that go all the way through to secure the mount so I only need to take that out and I'm good to go with jacking engine as normal - basically same idea as the front mount which I've done a few time before? Just getting my head around it before I jump in. Cheers Matt Quote Share this post Link to post Share on other sites
_Matt_ 33 Posted July 14, 2022 Anyway figured it out - for all of those that don't know - 13mm nut clamps bracket for o2 sensor and once removed you have access to the main bolt that runs through the mount. Remove bolt and you're free to jack up engine. Just as simple as the front mount. Just a note as sounds like the knowledge has gone - you cannot remove the wishbone on a vr6 without either jacking up engine/dropping subframe/remove sump. Sent from my SM-G960F using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted July 14, 2022 Good info, thanks for sharing. If you've taken any pics those might be useful too. Quote Share this post Link to post Share on other sites
Cressa 46 Posted July 16, 2022 On 7/14/2022 at 9:11 PM, MJA said: Anyway figured it out - for all of those that don't know - 13mm nut clamps bracket for o2 sensor and once removed you have access to the main bolt that runs through the mount. Remove bolt and you're free to jack up engine. Just as simple as the front mount. Just a note as sounds like the knowledge has gone - you cannot remove the wishbone on a vr6 without either jacking up engine/dropping subframe/remove sump. Sent from my SM-G960F using Tapatalk Late to the party I know, but last time I removed the sump to make it easier. What a ball ache 😂😂 Quote Share this post Link to post Share on other sites
Crasher 4 Posted July 17, 2022 On the VR6 auto and both versions of the R32 with DSG, you get this both sides. Quote Share this post Link to post Share on other sites
