vrmillerman
vr6 running like a 2cv help
anybody in the know please help my vr6 is running like a 2cv
i think its the cat so have got a new one and whilest doing so got a magnex cat back system fitting saturday
but could it be a faulty lambda sensor as well
any help would be great
kelly
First thing is to run a VAG-COM and see what faults it picks up.
This may lead you right to the bugbear rather then end up replacing parts that have no defects.
ok
i have replaced the cat oxygen sensor and put a new exhaust on
this has not cured the problem :(
the car sounds like its not firing on all cylinders i have a copy of vagcom and theres a problem saying controler not found
i tried the maf sensor from my other halfs vr6 sharan and that does not change the problem so its not that
i have checked all fuses there are all ok
i checked if all the relays were seated correctly they are
not too sure what to check now any ideas from any one that may know or have any other ideas
and ps a 2cv is a citreon with 2 cylinders
kel
cheers
im finishing work soon i will check these items out
and its a coil pack i guess as it does not have a dizzy and cap
did a vr6 ever come will a dizzy and rotor ?
by the way mines a 95 m vr6 in metalic blackberry black leather magnex cat back system k&n 57i and a shagged engine at the mo normally very quick
any ideas of which type of plugs to use i think its currently got champion eon2's and the std plug leads any help would be good
kel
VR's did come with a dizzy - pre '93 cars I think.
You should be using the OEM NKG plugs only and I'd check these first, especially 1 & 6 for fouling.
If the plugs look ok, spray a fine mist of water around the engine bay and see if you get some sparks (especially around the coil pack area)
The coil pack has 3 coils and one coil fires 2 cylinders. If your only missing on one cylinder only I doubt it's the coil pack, if on 2 this is more than likely the culprit.
If it's missing it won't be the MAF btw, but, depending on your ECU code it's unlikely a MAF from a Sharan will work anyhow.
Dutch
cheers i will get some on order once i have some funds
ps i have posted this in the vag com part of this forum but i will do the same here if any body knows fault caodes from vag com this is what it is saying
VAG-COM Version: Release 311.2-N
Chassis Type: 50 - VW Corrado
Scan: 01,02,03,08,15
Address 01 -------------------------------------------------------
Controller: 021 906 258 CP
Component: MOTOR 2,8L 6-Zyl.
Coding: PMC 1 HS
Shop #: 0261203565
6 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00561 - Shareware Version. To Decode all DTCs
15-10 - Please Register/Activate - Intermittent
00553 - Shareware Version. To Decode all DTCs
29-10 - Please Register/Activate - Intermittent
00518 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
00611 - Shareware Version. To Decode all DTCs
28-10 - Please Register/Activate - Intermittent
00513 - Shareware Version. To Decode all DTCs
03-00 - Please Register/Activate
Readiness: N/A
any help on this would be nice but please dont say register it im going to when i have some more funds
kelly
you da man dutch vr6
checked out the coil pack today took it off had a look for cracks have a couple of nice ones on there
i sealed them up and she worked like a dream for 20 mins
then went back to rubbish so i guess its a new one of them
should i go for a gsf or vw part any comments or experence on the gsf part (only cause its far cheeper)
let me know please
kelly
Fault codes:
00561 – Mixture adaption limits exceeded.
00553 – MAF defective or wiring short.
00518 – Throttle Position Sensor defective or wiring short.
00611 – Ignition Coil Pack Output 3 Short.
The common point to all these faults is one of three things.
But first check the fuses on the lower edge of the fuse / relay panel.
An intermittent ignition switch in the steering column breaking power to the ECU.
Or
A troublesome Fuel Pump relay (cover number 167).
Or
A troublesome ECU relay (cover number 109).
Do not change out the Coil pack, MAF, TPS. They are red herrings to the cause. From the faults, the order to test is the ignition switch 12 volts contacts. Next the fuel pump relay “167” and finally the ECU relay “109”.
The blocked immobiliser is sorted by spraying a little WD40 on the brown 3 pin connector (shiny black cable) that plugs into the immobiliser box located inside the dash behind the headlight switch. The other box is the spoiler control.
00513 – Engine speed sender but it also appears if the ECU is read with the ignition switched on but the engine is not running. Ignore.
cheers rw1!
iwill check the relays as i sometimes have a funny thing happen when i start the c she fires up and dies then i give a swift wack to the lower dash where the relays are and she fires up and stays running
i have taken the coil pack off and found large cracks around the plugs for 1 and 6 i sealed then with so liquid rubber and she started up on all 6 nice then went out for a test drive and lasted for about a mile and a half then went back to running real rough like on 4 or less
my girly has a sharan vr6 for the kids(as you do gotta be a vr) i was gonna try my coil pack on that to see what happens my thinking is if the sharan does the same its the coil pack
i will let you know sat afternoon when i test this
kel
