ben16v 0 Posted January 30, 2007 would it not be possible to do a refurb on `em ala haynes for now shouldn`t cost too much and should last long enough to save for new calipers or is it just a waste of time trying to save them?? Share this post Link to post Share on other sites
Lippy 0 Posted January 30, 2007 dunno - may try and effect a running repair, but I know that the discs are shagged as they are caked in rust and grime - therefore minimal rear brakes anwyay! still pass two MOTs since I've had them on, hence why i put it off... Share this post Link to post Share on other sites
Lippy 0 Posted February 5, 2007 brakes will hopefully be OK, going to get new discs, bearings and go from there ok quick question, been searching for ages for the location of the vac pipe that connects to the engine for the MFA mpg reading. I think this is disconnected, but want to make sure I am looking in the right place. Anyone got a pic? Share this post Link to post Share on other sites
Henny 0 Posted February 8, 2007 not sure yours has one Lippy... think they're the same as the VR6 and the MFA readings are done by the ECU on the 2.0 16Vs? anyone confirm? Share this post Link to post Share on other sites
Lippy 0 Posted February 9, 2007 would the ecu coolant temp switch bonk the mpg reading as it is in the wrong state and overfueling?? its really chuggy starting from cold, and the engine nearly cuts out without a little persuasion from the throttle Share this post Link to post Share on other sites
Lippy 0 Posted February 14, 2007 I'm tackling this weekend: - fitting new rear discs and pads, hoping caliper can be rescued! - rear wheel bearings - getting new new front tyres and refurbing two alloy wheels (local company discount!) - sort cold start problem / overfueling? and generally sooty exhaust (ecu coolant temp sensor a possibility) I need some help with the following, i've searched but I am finding it difficult to find 9a specific details - why is my MFA reporting 99.9 mpg. Confused, does the 9a use a vac pipe or is it via ECU? - if it is ecu driven, why will it have suddenly gone wrong. What sensors / parts combine to work this out? Share this post Link to post Share on other sites
Lippy 0 Posted February 15, 2007 come one guys - no one help? Share this post Link to post Share on other sites
matthewb1985 0 Posted February 15, 2007 check that the vac pipe is still attached to the back of the clocks Share this post Link to post Share on other sites
Mave 0 Posted February 15, 2007 http://the-corrado.net/.archive/forum/viewtopic. ... highlight= VAC pipe, even you said ;) Looking for why it's gone wrong now.. http://the-corrado.net/.archive/forum/viewtopic. ... ht=mfa+mpg http://the-corrado.net/.archive/forum/viewtopic.php?p=&t=192 any help? :| Share this post Link to post Share on other sites
Lippy 0 Posted February 15, 2007 aye - confuscated as its a 9a not a KR - can someone confirm it is a vac pipe issue and the MPG is not fed from ECU as per Henny's post above? Share this post Link to post Share on other sites
mrbeige 0 Posted February 15, 2007 It is via a vac pipe dude. The ECU isn't that clever! It could be leaking somewhere along the line or it isn't connected. The vac pipe connects to a pressure sensor on the back of the clocks and AFAIK to the rubber pipe just in front of the throttle body (there are two vac pipes there one for the MFA and one that goes to the airbox) Share this post Link to post Share on other sites
Lippy 0 Posted February 16, 2007 great exactly what I needed - I think I know which one your describing aswell. If its disconnected what other effects would that have if any? Share this post Link to post Share on other sites
mrbeige 0 Posted February 16, 2007 great exactly what I needed - I think I know which one your describing aswell. If its disconnected what other effects would that have if any? All it would affect is you MPG calculation as it uses the amount of vacuum to work out consumption of the engine AFAIK Share this post Link to post Share on other sites
Lippy 0 Posted February 18, 2007 Had a productive weekend for once! fitted new rear brake discs and pads, put two alloys in to be refurbed - turned out they were beyond repair... hastily rearranged some finances and got these for an absolute bargain. Innovit CTS 17x7 (http://www.inovit.com/main.asp) , brand new, never been on a car with brand new Toyo Proxes 204/40. I needed wheels this weekend, as would have no means of transport... wouldn't have been #1 choice but they are light, have great brake clearance so should last for a long time. What do you think? Share this post Link to post Share on other sites
Lippy 0 Posted February 18, 2007 p.s. not trying to copy the cheesewire mobile - although a set of APs and a turbo wouldnt go amiss :D Share this post Link to post Share on other sites
mrbeige 0 Posted February 18, 2007 I quite like them! Good skills.....mmmmm turbo :lol: Did you get the MFA working in the end? Share this post Link to post Share on other sites
ben16v 0 Posted February 19, 2007 looks nice i been thinking about some dark wheels recently Share this post Link to post Share on other sites
Lippy 0 Posted February 19, 2007 well at 7am this morning my car was stolen. anyone in the manchester area please keep an eye out / or if anyone offers the wheels please let me know - 07720844067 Share this post Link to post Share on other sites
vr6storm 0 Posted February 19, 2007 NO WAY mate!!!!! you must be gutted to say the least..............fingers crossed it will be found intact Share this post Link to post Share on other sites
Blue_Joe 0 Posted February 19, 2007 Noooooooooooooooooooooooooooooooooooo Gutted for you fella!! Share this post Link to post Share on other sites
Yandards 0 Posted February 19, 2007 FFS, hope you catch the scummers and the car is ok. Share this post Link to post Share on other sites
mrbeige 0 Posted February 19, 2007 well at 7am this morning my car was stolen. anyone in the manchester area please keep an eye out / or if anyone offers the wheels please let me know - 07720844067 Ah mate, that's proper schitt! Lets find them and knee-cap the backstards! Share this post Link to post Share on other sites
chubbybrown 0 Posted February 19, 2007 Terrible... I hope the car turns up intact. Share this post Link to post Share on other sites
Jim 1 Posted February 19, 2007 WTF!! Holy crap :( I hope it turns up safe. Please keep us posted on whats going on! Share this post Link to post Share on other sites
Lippy 0 Posted February 19, 2007 police have been around and got a statement, just got to wait and see. totally fucked off, as just spent the thick end of 700 quid on it since xmas including them wheels. Share this post Link to post Share on other sites
