girlracer
Someone please help me!
:cry: I have a 1989 corrado vr6/g60. Ihave owned it for 6 months and not too many problems. Last month I discovered my engine was a transplant when i tried to get a water pipe from vw. The one i had on my car matched up to vr6 passat! After investigation i found out my engine was from a 1993 passat (AAA 2.8 vr6) Iam now having running problems with it that nobody can diagnose. There are no diagnostic sockets! It starts ok, idles a little irratically but always has, drives ok at low revs but get on the open road and put my foot down and might as well be driving 1.1 metro. Spent god knows how much on it so far contemplating putting a match to it!!!!
I'm a litle confused. You bought a 1989 Corrado VR6 under the impression that it left the factory that way?
With respect to the problem I'm not the best person to offer a diagnosis as I've never even owned a VR6. If VAG-COM is likely to be able to find the fault I wouldn't think that retro-fitting the diagnostic sockets is a major job - if you can find the loom. I assume they're connected straight to the ECU.
With 34 views to this post I'm surprised nobody's replied. I guess they saw 'girl' in your name and curiosity took over!
So it was originally a G60 (were they around at '89?), but is now a VR?
Apparently VR's have a habit of idling slightly erratically, which is normal...
As for the lack of power when you put your foot down, I'm afraid I can't help you there, but I'm sure it won't be long before someone knowledgeable comes along...
Hope you get it sorted!
unless you can hook it upto VAG-COM or know someone with a factory fitted VR6 engine,sounds like you'll have to maybe go down the route of replacing all the sensors to see what ones fubar'd...............if you know someone with a VR engine in their car then you could always swap over sensors to see what works and what doesn't
Are your wheels 4 or 5 stud btw?
...nothing to do with your problem, just trying to figure how well it was converted.
Dutch
DieselGolfWales, love the avatar! :)
Sorry for being off-topic, regarding the problem I can't give any advice that hasn't already been given here.
Do you know who did the conversion? Maybe they relocated the diags port? Maybe they wired up the standard G60 ports (under the gear gator - the 2x2 plugs)?
Wouldn't an 89 Corrado make it a 16V to begin with?
Since the 89 1800 valver had no ABS or engine management ECU, it's minus the diag port.
Chances are the K line for the ECU is tied up somewhere under the dash, or worse, snipped off completely during the transplant. Look for a thin grey/white wire behind the centre console, if not there I'll find out which pins on the ECU you need to run wires to in order to get your comms working again. The socket you can lift from any scrapper Golf, Passat or Corrado VR6, in fact you may aswell get the socket and all associate wiring and hook it up to your ECU.
I wouldn't worry about the Passat water hose too much, so long as it fits and does the job. A lot of the same VR6 parts were utilised across the spectrum of models that used that engine.
You need to get that diag port sorted before we can go any further......but if it feels down on power, it could be the usual suspects.....cam sensor (or hall sender if it's a distributor model), MAF sensor or the lambda probe.
How are the spark plugs, HT leads, air filter etc?
I'd have thought the socket would be around somewhere... maybe try and contact a previous owner?
Also - I reckon the stored faults could be read by sticking the ECU into another car and hooking them up to VAGCOM without turning the ignition on...
Or I'd say any reasonable engine management specialist should be able to read them directly from the ECU - Bosch service centre maybe??
Erm...... ECU Reset = Total memory loss including fault codes. :wink:
Where are you in hants? Ross (Tekara on here) and I are both in Hants and he now has a full vag com set up on a laptop. If your reasonably close give us a shout and we could take a look and see whats been done to yours no probs.
Sorry, speaking for Ross there too, but im sure he wont mind.
:-P Cheers guys for your help, for those who who didnt catch on it left the factory as g60 and had vr6 transplant. Think my best bet would be to follow Kevs advice and try and trace wires from ecu. Question: where the bloody hell is the ecu? Sorry its a women thing!
LOL>.it's not a women thing...my wife would'nt know a ECU if it jumped out of THE SCUTTLE PANNEL (( top right hand side of the engine bay below the window on any standard raddo ive had )) and unchained her from the sink :wink:
As Nick has volunteered my assistance it would be rude not to honour it.
Thanks guys. the car is currently in bognor regis as it is out of MOT. where bouts you from? how much will it cost me for boys to come and have a look at it?
Well, while we are on the subject of helping each other, my VR always likes a run out.....
Give us a shout if you want another pair of eyes looking at it
