david14 0 Posted October 9, 2006 I NEED BIG TIME HELP. i have a 2l 16v corrado. it drives fine when started cold. when the engine heats up the car backfires and refuse to run smooth. the idel will go below 10rep. when pressing on the acclerator there is no power and the car will not reve and then all of a sudden it takes off. when turning off the engine the car backfires for 1-5seconds. please help. plese advise which garage to take the car to get it repaired. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 9, 2006 Can't advice on a garage if we don't know where you are ... Have you checked plugs/distributor/leads .. ? Quote Share this post Link to post Share on other sites
Phil K 0 Posted October 9, 2006 De-Caps'd your post - please don't shout ;) It really could be a number of things causing your running problems... my guess is it's air flow meter related - I say this as they are the bain of my life and I'm on my fith one in 2 years!!! Depends where you are as far as suggesting where you should go... if you're in the south the I wouldn't consider anywhere other than The Phirm They really know what they're doing and don't charge the earth! Good luck what ever you decide... Quote Share this post Link to post Share on other sites
Crasher 4 Posted October 9, 2006 The most common cause of this is a faulty distributor, new from VW they are less than £100. Quote Share this post Link to post Share on other sites
saysomestuff 0 Posted October 9, 2006 dizzy sounds like first port of call, unless you've got some serious coke issues... Quote Share this post Link to post Share on other sites
mistrall 0 Posted October 10, 2006 dont fret my freind , does sound like the guys above says , could be one of a few things , to me sounds like the air/fuel mix is wrong Quote Share this post Link to post Share on other sites
nocrap 0 Posted October 10, 2006 Agreed, dont worry yet! Start with the easy stuff, check/change the sparkplugs, HT leads, dizzy cap, blast out the throttle body and ISV with carb cleaner and make sure you have no leaky hoses. Quote Share this post Link to post Share on other sites
