Swompy 0 Posted April 12, 2010 Sounds good vaughan, your list looks like it has half the things on it I want to do to mine 8) Quote Share this post Link to post Share on other sites
Guest Posted April 12, 2010 All very nice. My Storm is down at D&G at the moment... hoping to pick it up later this week. I also spent time giving my front bumper some attention over the weekend but it is the 8v one in need of repair after the dog incident in Jan. But, it's very interesting seeing how it is all put together as I've big plans for the one on my Storm when I get to the stage of sorting it out. I've taken the bumper iron itself off which makes me think nylon coating is on the cards :grin: :grin: :nuts: 8) Quote Share this post Link to post Share on other sites
vornwend 0 Posted April 13, 2010 Replaced the badly scratched drivers side glass today with one salvaged from our breaking project. This is the second time I've done this job now and it was no more pleasant than last time :? Reasonably easy to get the glass out but a mare to get back in for some reason. Took care to see if there was any obvious problem but could not see one :scratch: I marked where the vertical scratches had been and examined the felt on the inside of the strip - all good and no metal exposed. The last time I did this all was fine for about 3 weeks and then over the space of two days they appeared so hopefully it was something as simple as a piece of grit getting trapped in there and won't recur. All working as it should and no scratches appearing! Fingers crossed and touch wood (not glass) it will remain this way! corradowindow.jpg[/attachment:3khajyhc] Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 13, 2010 Good work, Vaughan- nice and minty :) Quote Share this post Link to post Share on other sites
sprinterVR6 0 Posted April 23, 2010 mate - your car is spot on. And like vaghag, it's pretty much how I want mine to end up like. I know you mentioned the new ride height as being from centre of wheel arch to ground (i think), but would you know what the drop was in mm's? Was it 40mm? Thanks Quote Share this post Link to post Share on other sites
vornwend 0 Posted April 23, 2010 mate - your car is spot on. And like vaghag, it's pretty much how I want mine to end up like. I know you mentioned the new ride height as being from centre of wheel arch to ground (i think), but would you know what the drop was in mm's? Was it 40mm? Thanks Hi - found some scribbled notes I made at the time: Was 630mm at the front and 670mm at the back Aim was to get to 585mm at the front and 600mm at the rear So a 45mm drop at the front and 70mm at the back All this was based on Goldies old Storm cos I thought the stance was bang on. HTH Vaughan Quote Share this post Link to post Share on other sites
OSV 0 Posted April 23, 2010 mate - your car is spot on. And like vaghag, it's pretty much how I want mine to end up like. I know you mentioned the new ride height as being from centre of wheel arch to ground (i think), but would you know what the drop was in mm's? Was it 40mm? Thanks Hi - found some scribbled notes I made at the time: Was 630mm at the front and 670mm at the back Aim was to get to 585mm at the front and 600mm at the rear So a 45mm drop at the front and 70mm at the back All this was based on Goldies old Storm cos I thought the stance was bang on. HTH Vaughan Is 585 and 600 where your ride height finished up? Any side on pics please 8) Quote Share this post Link to post Share on other sites
vornwend 0 Posted April 23, 2010 Is 585 and 600 where your ride height finished up? Any side on pics please 8) Pretty much where it ended though its never as easy to be as precise as that - the rear I found especially difficult to get balanced - I'd do one side and then the other side woukd be out - was hard to work it out! Pretty sure it settled a bit in the following 6 months and I've raised it back up a couple of times, especially at the front There's a selection of side on shots on page 1 Quote Share this post Link to post Share on other sites
vornwend 0 Posted April 23, 2010 Not much time before Stanford so have made an early start - outside done, insides may get done but sunshine means there be may be other things to do 8) Anyway here she is making a brief excursion into the volcanic ash laden outdoors corrado2304a1.jpg[/attachment:1r8d3kk3] And also treated some rust that had cropped up under the drivers door seal (vertical section)climatronic wiring-Golf from May 01.pdfcorrado2304e.jpg[/attachment:1r8d3kk3]- only noticeable because the seal was getting uneven. Seen this on a number of Cs and been meaning to sort it for ages.2.8l 24v Climatronic system.pdfcorrado2304d.jpg[/attachment:1r8d3kk3] Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 23, 2010 Great work! Gotta start cleaning mine too- scared of that layer of glass dust that's all over my car :? Quote Share this post Link to post Share on other sites
coullstar 0 Posted April 23, 2010 Spic and span. How did you treat the rust on the door, does the seal just come off? Ive got something similar on mine. Quote Share this post Link to post Share on other sites
vornwend 0 Posted April 23, 2010 Spic and span. How did you treat the rust on the door, does the seal just come off? Ive got something similar on mine. You can just pull seal just pull away from the frame with your fingers, no need to take it all off- just wedged it away from the frame and then sanded the rust away to bare metal and then painted with Hammerite Rust Beater. It wasn't too bad but was only gonna get worse - the C we're breaking at the moment had it really bad which is what prompted me to tackle it. Quote Share this post Link to post Share on other sites
vornwend 0 Posted May 8, 2010 Picked up the C from D&G today. Very, very pleased with the work and the feel of the car after all the work: Powder coated subframe and anti roll bar - swap out Neuspeed rear ARB Roll bar drop links, ball joints, bolts, retainer plate and roll bar bushes New wishbones and R32 bushes Front VT road mount Gearbox VT road mount Front wheel alignment The car handling feels very "tight and right" - really confidence inspiring in and out of fast bends :) Can't wait to try it out again on some more local roads. Can't praise Dave and Graham enough for the quality and care that they take in all their work :salute: Graham took so much time and care on the front wheel alignment which proved quite a challenge - pretty sure you didn't charge me enough labour today for that. Thanks also to Dave for the Bacon bap (something of a tradition at D&G) Good to chat to Ed and Jim who there today as well - at one point I counted 9 Corrados :shock: I lost the impromptu competition to see who had the most knackered aux tensioner bearing :wink: Dave is sending some photos of the work so will post those soon. Quote Share this post Link to post Share on other sites
Guest Posted May 8, 2010 Nice one. That sounds like the sort of work I need to do on mine when I swap the sub frame over. Trouble is after the rear beam and engine bay work my purse needs to recover! It's good having a whole chunk of drive / suspension type things done at the same time as it really makes a difference. See you next Saturday ? :) Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted May 8, 2010 Good to chat to Ed and Jim who there today as well - at one point I counted 9 Corrados :shock: I lost the impromptu competition to see who had the most knackered aux tensioner bearing I was there too in my Flash Red VR6, Flash Red jacket and hat. Still quite new to this Corrado ownership and but getting the hang of it slowly. Your Storm did look very tidy! Quote Share this post Link to post Share on other sites
vornwend 0 Posted May 8, 2010 Good to chat to Ed and Jim who there today as well - at one point I counted 9 Corrados :shock: I lost the impromptu competition to see who had the most knackered aux tensioner bearing quote] I was there too in my Flash Red VR6, Flash Red jacket and hat. Still quite new to this Corrado ownership and but getting the hang of it slowly. Your Storm did look very tidy! Should have introduced ourselves! Lovely VR you have there Quote Share this post Link to post Share on other sites
OSV 0 Posted May 8, 2010 Top work on a top car, can't beat those D&G boys :salute: Quote Share this post Link to post Share on other sites
Jim 1 Posted May 8, 2010 Good to chat to Ed and Jim who there today as well - at one point I counted 9 Corrados :shock: I lost the impromptu competition to see who had the most knackered aux tensioner bearing quote] I was there too in my Flash Red VR6, Flash Red jacket and hat. Still quite new to this Corrado ownership and but getting the hang of it slowly. Your Storm did look very tidy! Didn't realise you were a forum member mate.. sorry! Should have introduced myself properly! It was my VR on the ramps whilst you were there. Your VR looked excellent and I'm sure it's going to drive like an absolute peach once you've had all that work done it!! :) Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 8, 2010 What you had done Jim? Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted May 8, 2010 Thanks also to Dave for the Bacon bap (something of a tradition at D&G) Yes..... it seems I'm better at bacon baps than seized track rods :lol: Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted May 8, 2010 Nice one, mate 8) Sounds like it's well sorted now. I've never driven it... ;) Quote Share this post Link to post Share on other sites
vornwend 0 Posted May 8, 2010 Nice one, mate 8) Sounds like it's well sorted now. I've never driven it... ;) We'll have to sort that out asap then! You're welcome anytime Quote Share this post Link to post Share on other sites
Swompy 0 Posted May 8, 2010 Sounds good, even more of a monster now then Quote Share this post Link to post Share on other sites
vornwend 0 Posted May 8, 2010 A few shots of the goodness that went on.........Corrado92.pdfDSC04035[1].jpg[/attachment:3okp5int]passat climatronic wiring diags.pdfDSC04036[1].jpg[/attachment:3okp5int]climatronic wiring-Golf from May 01.pdfDSC04037[1].jpg[/attachment:3okp5int]2.8l 24v Climatronic system.pdfDSC04045[1].jpg[/attachment:3okp5int]DSC04033[1].jpg[/attachment:3okp5int]Everything else looks scruffy now though :wink: Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted May 8, 2010 Scruffy! :roll: Gotta get my subframe, wishbones & rear beam done now! Quote Share this post Link to post Share on other sites
